zanepetty
tranny life expectancy!
zanepetty
Hey again guys. My 753 tractor has an hour meter installed on it. (Very neatly done.) It says it now has 1739 hours on it. I would say it might have a little more than that if its not original which I'm guessing its not? The meter does appear old though. How long can a trans last in a 753. (Approximately) I know you can't tell me exactly but it doesn't jump out of gear going up or down hill. Just wondering. Thanks guys, I appreciate it,
Zane
Edited by zanepetty
Wishin4a416
The one I just refurbished for my 310 [Out of a 416] had over 3000 hours on the meter. I changed a bearing and seals and gasket and had an axle worked on. Some of the gears showed wear but it is still working. I think if you keep the oil changed and refrain from grinding gears, they wll go a long long time.
zanepetty
I try to. I want to make it last as long as possible!
chazm
Like Wishin said... they will last a long, long time, AS long as your not grinding gears in it. Your tractor was build in 1963 in the USA , Not like the box store ones today that are stamped steel & plastic. If you do routine maintenance to it,  your good         :handgestures-thumbupright:
chasm    :flags-waveusa:
zanepetty
My little tractor gets babied I'll tell you that Haha! She grades the gravel drive but I always come to a complete stop before a change gears and its usually always run at idle speed. It will grind into the first gear I put it in upon initial start up but that's it. And its not a bad grind at that. It does have the correct amount of 85-90 wt oil in her as well.
  • Similar Content
    • eo1bart
      By eo1bart
      Looking for a gearbox with 1 1/8" axles for my 312. Ok if it needs rebuilding.
      Located in the New England area
    • cheesegrader
      By cheesegrader
      About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
      I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
      Does anyone remember who made this awesome mod, and where I can find them?
    • giant_g2
      By giant_g2
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • BrianStasC-101
      By BrianStasC-101
