Ride Away59
1955 Rj35 Cable steer
neil
Holy Smokes
Great find Al
stevebo
That is the real deal for sure !!!!!!!!!! Super find. Has the right rear tires too !!
Ken B
Looks rough? You kiddin me? With a little elbow grease and a little detailing I think it looks just right. Nice score!
AMC RULES
Love those original tires too.
Ride Away59
The best part of this barn find was that it was only 5 minutes from my house!! Its been in a barn for years! Every thing spins freely as far as moving the tractor and steering
Kelly
I would clean it and preserve it not restore it, it looks pretty nice.
clemedc
Great find for sure, awesome tractor.
VinsRJ
What have I been telling you? Be patient!
Nice score!
Interesting that it has an early brake kit on it too!
Edited by VinsRJ
dennist
Wow, what a great find from a local guy! Wonder how many of those cable steers are still out there?
Jake Kuhn
Amazing find!
stevasaurus
What a great find and a great story. :)
55rj35jr
WOW!! Rare find! I've got a cable steer restored that was real rough, but yours looks to be in real good condition if I were you I'd just clean it up and leave it original....awesome tractor... :bow-blue:
grnlark
Now that's awesome!
fireman
RJ35Hunter is going to be all over that! Break out the check book Clay!!!!!
Eriks Red horse herd
Like WOW another one saved. Is the steering wheel Aluminum ? Also is that a Speedex walk behind  in pic number 1?
Ride Away59
The steering wheel is iron. The walk behind is a pond garden tractor.
stevebo
Iron wheel will make it not the very early 55. It is what I would call "second generation" 55.
rj35hunter
Jeff, that is an awesome find but he has been looking or a RJ35 for a while & I got enough to work on for a while! :lol:
fireman
That's true Clay. I've seen the pictures of your basement/shop!
Would love to see a pic of your walk away if'n you please?
Ride Away59
Its not mine
krazy_horse
Boy, What a nice find! As Kelly said "Clean it up and preserve it ".
LFDRET
I think your tractor is more rare then you think. from the pic's I think I notice thing that you would not see on a normal 1955 Rj. Please check some of the things in the list below.
Early 1955 RJ-35 things
Later 1955 RJ-35
Very Early 1955 RJ-35
Gas tank
On tank stand
Strapped to hood
On tank stand
Front axle pivot stop
Solid steel across axle
2 square blocks at each end
No Axle pivot stop
Lift lever
Solid 3/4 “ round
Push button release
Solid 3/4 “ round
Motion lever
No stop
Stop welded on end
No stop
Engine stop
Brass push knob
Toggle switch
Missing
Belt tension spring
3 hole in rear to attach
1 hole in rear to attach
Steering wheel column hole in hood
Oval
Oval
Round and tight
Lift cable hole to hitch
Oval
Oval
Round
Primary pivot bar assembly
Is wider than other early RJ’s
Drive pawl in hubs
Machined
Machined
One of them is sawed not machined (The other might have been replace with new wheel hub casting in 1971)
Variable speed pulley
3 roll pins /3 holes for slide
1 key way for slide
1 roll pin / hole for slide
From what I see in the Pic's The Steering wheel column hole in the hood is round and just big enough space for the wheel column to go through C. Pond must have changed it to a oval to make it easier to remove the hood.
I do not see any Front axle pivot stop -  axle stops were added later for safety.
​As for the Steering wheel - the aluminum wheel Broke easily and replaced with a cast iron steering wheel
If it does have a round hole for the steering column, and there is not axle pivot stops. I do not think any one can disbute that this is one of the first RJ.s  - VERY VERY NICE FIND
Edited by LFDRET
jwl
Its not mine
So because its not your tractor, you cant take a picture of it? Im confused.
