Austin860 82 #1 Posted August 14, 2013 What spark plugs should I have in my 18hp kholer? It's off a d180 Share this post Link to post Share on other sites
Marv 966 #2 Posted August 14, 2013 Champion H10. Marvin Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #3 Posted August 14, 2013 I have been looking for this application but see conflicting part numbers. The original Kohler number is 25 132 10S but it is a poor idea to use a conversion list to find a replacement. It will have the same physical dimensions but the heat range can be off by a mile. Finally found a 18hp twin in an old Champion book that lists their reccommended plug as RV17YC for Wheel Horse gapped at .025". 14mm, 5/8`hex, .460`reach with a tapered seat so uses no gasket. They do list the 18hp V-Twin as using RC12YC. 14mm, 3/8`reach, 13/16`hex and uses a gasket. I did come across the H10 for this model but now believe it is not correct 14mm, 7/16`reach, 13/16`hex and uses a gasket. Whatever make of plug you get use their application charts to get the correct one. Garry Share this post Link to post Share on other sites
Jeff-C175 7,203 #4 Posted August 14, 2013 (edited) Googling the Kohler part number that Garry posted comes up with this: http://www.rcpw.com/kohler-engine-parts/genuine/25%20132%2010S.html Which is showing the H10C or RH10C (resistor) as aftermarket replacement. BUT, this plug appears to be for the K series SINGLES. Is this an 18 HP TWIN? What is the engine model? The KT twins use the RV17YC plug... Edited August 14, 2013 by Jeffpicks Share this post Link to post Share on other sites
Jeff-C175 7,203 #5 Posted August 14, 2013 That engine is a K482, correct? http://www.kohlerengines.com/onlinecatalog/pdf/en_607.pdf Kohler manual for that engine lists 235040-S as plug part number. Putting this number into rcpw.com crosses back to the 25 132 10-S number that crosses to the H10 in the previous post. Share this post Link to post Share on other sites
pfrederi 18,334 #6 Posted August 15, 2013 Autolite shows 216 for K482 motor (That crossed to H10) champion) Share this post Link to post Share on other sites
