Austin860
Correct Plugs For A D180
Austin860
What spark plugs should I have in my 18hp kholer? It's off a d180
Marv
Champion H10.
Marvin
gwest_ca
I have been looking for this application but see conflicting part numbers. The original Kohler number is 25 132 10S but it is a poor idea to use a conversion list to find a replacement. It will have the same physical dimensions but the heat range can be off by a mile.
Finally found a 18hp twin in an old Champion book that lists their reccommended plug as RV17YC for Wheel Horse gapped at .025". 14mm, 5/8`hex, .460`reach with a tapered seat so uses no gasket.
They do list the 18hp V-Twin as using RC12YC. 14mm, 3/8`reach, 13/16`hex and uses a gasket.
I did come across the H10  for this model but now believe it is not correct 14mm, 7/16`reach, 13/16`hex and uses a gasket.
Whatever make of plug you get use their application charts to get the correct one.
Garry
Jeff-C175
Googling the Kohler part number that Garry posted comes up with this:
http://www.rcpw.com/kohler-engine-parts/genuine/25%20132%2010S.html
Which is showing the H10C or RH10C (resistor) as aftermarket replacement.
BUT, this plug appears to be for the K series SINGLES.
Is this an 18 HP TWIN?  What is the engine model?
The KT twins use the RV17YC plug...
Edited by Jeffpicks
Jeff-C175
That engine is a K482, correct?
http://www.kohlerengines.com/onlinecatalog/pdf/en_607.pdf
Kohler manual for that engine lists  235040-S  as plug part number.
Putting this number into rcpw.com crosses back to the 25 132 10-S number that crosses to the H10 in the previous post.
pfrederi
Autolite shows 216 for  K482 motor  (That crossed to H10) champion)
