Countdown To Christmas!
darg
418A
darg
Can someone please maybe tell me what type of auto trans in on this 418A ID#3118KEDI >
Need a manual for complete  tractor  18HP  twin onan
what type of oil and how  many qts'
oil filter# and where can I get one
# for the drive belt
I think you fellows for the help.
Jeff-C175
3118KEDI
Check number... not sure if first digit is correct, but if it is, it might look more like this   31-18KE01
Note that the second to last digit is probably a ZERO, not the letter D.
That part number tells me your machine should be a KOHLER with an EATON tranny.
Are you sure the engine is an Onan and not a Kohler Magnum 18HP twin?  If it is, then it's been swapped at some point in it's life.
http://www.jackssmallengines.com/Jacks-Parts-Lookup/Manufacturer/toro/4087/3603
Did you look in the 'manuals' section here on RS ?
Edited by Jeffpicks
darg
Jeffpicks
I will check the # again. It is hard to tell
darg
Jeffpicks.
Looks like 3118KE01           20273
 I do not have the engine tin. to tell the make. The guy I bought the 418 from said it was a Onan.. which is apart in a box. Everything alum. except  the jugs
Any series of the tammy?
thanks
I checked the manual section
dennist
Should be a Kohler twin Originally
GlenPettit
This might be a good reason to not license Lawn Mowers here:
or this:
Edited by GlenPettit
darg
Is there any way to tell what make without the tin?
Jeff-C175
Yeah, the "K" in the model number says Kohler.  That number says it's a 1987 418-A .
darg
Thanks Jeff , I will check out the manuals you listed
Jeff-C175
I dunno... maybe look at all the parts and see if you can find some part numbers?  Should be able to find the Magnum 18 manuals at the Kohler website, might be some pics you can compare parts you have?
dennist
Can you look at the intake and carb just compare to the Onan/Kohler?
darg
On carb. where the y pipe bolts up to the carb # 5205318  No K or O     Any  references to the #?
Thanks
dennist
If you post a pic of the carb we should be able to help.
darg
Checked at parts tree site and the # 5205318 comes up as a kohlor
thanks everyone for the help
darg
can someone give me a part # for the 400 filter?
Also the parts manual for the 400 trans & the 418A parts manual
thanks
Jeff-C175
Why not head on over to the manuals section and see if you can track down what you need?
This is the page that comes up if you go up to the top and click on the "MANUALS" link in the bar across the top of page:
http://www.wheelhorseforum.com/files/
You know the year and model number of your machine now...
Or, click on that link to Jack's Small Engines that I posted in #2 and look up any part ya want?
or rcpw.com or partstree.com or even toro.com ... there's any number of sites that sell parts and have illustrated parts lists.
Edited by Jeffpicks
gwest_ca
The original engine for the tractor model number 31-18KE01 is listed as being M18QS-24510
If you go to http://www.partstree.com/parts/
and type Kohler in the 2nd box and M18-24510 in the 3rd box the illustrated parts lists will come up.
Garry
