"D"- Man 827 #1 Posted August 8, 2013 I have just finished a mock-up of my 18 Auto with extra wide fenders. I noticed that the stock fenders did not cover the whole width of the 12" tires, and would not cover dual 15" ags sooo... I took them to my welder friend along with a pair from my parts tractor and asked if he could take four narrow fenders trim off opposing edges of each and weld them together to make two wide fenders. He also is quite handy at body work and agreed to do it. I only had two extra holes in each of one pair (where a previous owner had replaced the original tail lights with a wider base) the other fenders were unmolested. I had my friend fill in the extra holes, so all that remained was the 4 mounting holes at the front and 6 holes at the rear. This way the wider fenders can accomodate two reflectors each and two tail lights each!!! I also may try to use a section of footrest from the parts tractor to sort of fill the void between the extra mounting holes (those on the outside) and the original footrest. Still trying to work out a design that comes close to looking factory. Looks like files are too big, I try in another post. 2 Share this post Link to post Share on other sites
"D"- Man 827 #2 Posted August 8, 2013 More pics hopefully... 5 Share this post Link to post Share on other sites
AMC RULES 37,141 #4 Posted August 8, 2013 That's gonna look great...nice work. Share this post Link to post Share on other sites
KC9KAS 4,741 #6 Posted August 8, 2013 That is so cool..........Thanks for the photos. Share this post Link to post Share on other sites
Sparky-(Admin) 21,544 #7 Posted August 8, 2013 Looks good, but lookin forward to the pics with the wide rubber in em. Mike............ 1 Share this post Link to post Share on other sites
"D"- Man 827 #8 Posted August 9, 2013 Oh and just for looks ??? Dual chrome exhaust tips. 4 Share this post Link to post Share on other sites
brandonozz 168 #9 Posted August 9, 2013 Very cool, I will be looking forward to seeing the tires mounted and how it looks all together. Share this post Link to post Share on other sites
SousaKerry 502 #10 Posted August 9, 2013 I would tuck two headlights under the front of each fender and make it look like a IH farm tractor Share this post Link to post Share on other sites
chevyaddict83 39 #11 Posted August 9, 2013 I would tuck two headlights under the front of each fender and make it look like a IH farm tractor that's the ONLY reason I want a gt14 or the 18auto. The recessed btail lights. Looks cool. www.perfecttrimlawnandgardencare.com Share this post Link to post Share on other sites
JamesBe1 82 #12 Posted August 10, 2013 Wow, that's excellent. If I recall correctly, there are braces under the fenders on a normal set of fenders. Did you use the old ones over or did you fabricate longer ones to accommodate the extra width? Share this post Link to post Share on other sites
"D"- Man 827 #13 Posted August 10, 2013 That's gonna look great...nice work. Thanks Craig, I think so too! Share this post Link to post Share on other sites
"D"- Man 827 #14 Posted August 10, 2013 That is so cool..........Thanks for the photos. Thanks Ken, you are very welcome. Share this post Link to post Share on other sites
"D"- Man 827 #15 Posted August 10, 2013 Looks good, but lookin forward to the pics with the wide rubber in em. Mike............ Thanks Mike, I probably will try to just do a hydro trans bolt-on with hubs wheels and 12" tires, after I get the wheels (that I had sandblasted) painted and tires mounted to see how it's going to look for myself... then I will take pics and post. Share this post Link to post Share on other sites
"D"- Man 827 #16 Posted August 10, 2013 Very cool, I will be looking forward to seeing the tires mounted and how it looks all together. Thanks Brandon, Tires mounted... hopefully soon, see it altogether well, lets just say that may be awhile yet as I am still trying to sort out some "mild" modifications along the way and they are taking a little longer than expected. Share this post Link to post Share on other sites
"D"- Man 827 #17 Posted August 10, 2013 I would tuck two headlights under the front of each fender and make it look like a IH farm tractor Thanks SousaKerry, I am currently trying to sort out how to fill-in the areas from the extended fenders to the footrests as this will offer a little support to the front of the fenders, I hope. Share this post Link to post Share on other sites
"D"- Man 827 #18 Posted August 10, 2013 I would tuck two headlights under the front of each fender and make it look like a IH farm tractor that's the ONLY reason I want a gt14 or the 18auto. The recessed btail lights. Looks cool. www.perfecttrimlawnandgardencare.com Thanks David, (I did get that name right I hope) I think it looks pretty cool myself, I am hoping to get the other two red lenses soon and see how all four tail lights will look! Share this post Link to post Share on other sites
"D"- Man 827 #19 Posted August 10, 2013 Wow, that's excellent. If I recall correctly, there are braces under the fenders on a normal set of fenders. Did you use the old ones over or did you fabricate longer ones to accommodate the extra width? Thanks James, you are correct. The braces from the original fenders were mounted at the rear, I am moving these to the middle. for the rear braces I am cutting in half a channel from my parts tractor (part #103226) I have drilled new holes to accommodate the rubber bumpers from the spare braces. This will provide support out to 10-1/2" the extra wide fenders are almost 14" wide. Share this post Link to post Share on other sites
"D"- Man 827 #20 Posted September 11, 2013 (edited) Well it has been quite some time since the last update. Redoing a transaxle in part was a little more time consuming than I anticipated! I also redid the two hubs, spacers and finally received my rear wheels back from the sand-blaster/powder coater (primer only) so I painted them. I chose Gloss White just because I really thought it would make them stand out more than the Linen Beige. Hope to have the tires mounted and wheels bolted to the hubs on my next post. One picture image was too large, sorry. Edited September 11, 2013 by TWIN54 3 Share this post Link to post Share on other sites
groundhog47 347 #21 Posted September 11, 2013 Extremely impressive, do you plan to activate the exhaust, that is really neat? Addition of dual rear lights very nice touch. As am unfamiliar with most of the BIG Horses, as well as new what are the four bolts in the hub for (not being smarty, just curious); friend pacer has one and haven't crawled all over it yet to learn. Just know the D's if that what you have are mega tractors compared to mine. 1 Share this post Link to post Share on other sites
"D"- Man 827 #22 Posted September 12, 2013 (edited) Extremely impressive, do you plan to activate the exhaust, that is really neat? Addition of dual rear lights very nice touch. As am unfamiliar with most of the BIG Horses, as well as new what are the four bolts in the hub for (not being smarty, just curious); friend pacer has one and haven't crawled all over it yet to learn. Just know the D's if that what you have are mega tractors compared to mine.Thanks Gerry, no, I do not plan on activating the dual rear exhaust. I do not even know if they would be in the way of the three point hitch, or any of the rear attachments. The four bolts per hub are for securing the turning brake discs. I do not have any yet, because the tractor that I purchased a partial system from was a working unit and the risk of damaging the hubs was not worth trying to remove them. I also need the rods to complete my T-brake system. P.S. this model is considered an 18 Automatic, which is the predecessor to the "D" series models. Mark. Edited September 12, 2013 by TWIN54 Share this post Link to post Share on other sites
"D"- Man 827 #23 Posted January 7, 2015 (edited) "I also may try to use a section of footrest from the parts tractor to sort of fill the void between the extra mounting holes (those on the outside) and the original footrest. Still trying to work out a design that comes close to looking factory." Just a slight bit of an update to sorting out the widened footrest design. What I decided to do is cut opposing edges off the two footrests from the tractor I am restoring and the two from my parts tractor. This approach seemed like the only logical design to accomplish a "factory" look. When the cuts were completed on the two pieces for the left footrest I test fitted them only to discover that the piece of angle I had clamped to one as a guide for my cut had been misaligned and about a 1/8" gap was present for the length of a few inches. On the two cuts for the right footrest the surfaces were filed to fit without any issues. So now I have turned these over to the welder, but was told it may be awhile before he can fit these into his schedule. I only took one picture of the left side with the pieces in place. Since I have purchased all of the parts that I needed for turning brakes* {most of which are new old stock} I am planning on adding this option to the tractor. This requires that the middle of the front of the right footrest will have to remain open, so consequently I will also leave the middle of the front of the left footrest open just for the sake of keeping things symmetrical. *A couple of the rods and the disc's are not included in the picture as these were still on the parts tractor when this pic was taken. Edited January 7, 2015 by 23 Automatic LSE 3 Share this post Link to post Share on other sites
Brrly1 1,146 #24 Posted January 7, 2015 Lookin' good Mark!!! Can't wait to see at the show! Share this post Link to post Share on other sites
"D"- Man 827 #25 Posted January 17, 2015 ...my 18 Auto with extra wide fenders... I took them to my welder friend along with a pair from my parts tractor and asked if he could take four narrow fenders trim off opposing edges of each and weld them together to make two wide fenders. I was asked, in a P.M. about the seam in these extra wide fenders, so I removed one and snapped a picture of the joining area to show where the weld is. I have also posted a picture of the edges that were trimmed off. You should be able to click on the image in order to enlarge for detail. 1 Share this post Link to post Share on other sites
