melonman
418A PTO clutch facing/ backing plate X-Reference compatiblility
melonman
Hey guys, I am looking at needing to resurface/ replace PTO clutch facing / plate. I have a 31-18KE01 ('87 418-A). Diagram shows the assembly as PN 111238. Wondering how much difference there is between those found on 417-A or 312-A whcih all use 103817.
The individual (component) part numbers I have found from those selling (on ebay) and mentioned on a forum are 4365 (facing or plate and/or facing only) & 6657 (rivets (or plate?). In the Toro digram this is only listed as an assembly form what I can see rivets not separate from friction or backing plate.
I found an ebay seller with plate with material listed as 4365 & 6657. Are there different thickness and diameters for these-I found another selling the assembly as 103140 & 94-6650 that says are compatible with MANY of the C-series, B-series, etc. etc.
Can anyone verify that there are any difference or a cross reference for those that are either discontinued part numbers or compatible? I did see someone mentioned that the plate itself they received from Toro was thinner and they needed to shim to make up for the difference.
Any help? (-not looking for advice on how to do the friction material replacment-yes I know; I'm sure it is not that difficult.)
Thanks,
Larry
Jeff-C175
From:  http://www.mowpart.com/94-6650-toro-ass-y-clutch-plate.html
Part Number 94-6650         Replaces 103140, 103477, 103817, 111238, 114881
The newer clutch discs are bonded vs. riveted.  They used to sell the lining and rivets separately, and the ones you see on ebay have to be NOS parts.
Edited by Jeffpicks
  • Similar Content
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • davidfindlay
      By davidfindlay
      Looking to find a new home for my 84 (I think) C-145. It has a dump trailer with the enclosure for leaves, the PTO impeller to get the leafs into the trailer, the hoses for deck-to-impeller, impeller-to-trailer.
      I haven’t run it in over a year.
      The battery and the cable to the battery probably need to be replaced.
      Comes with a new head gasket still in the bag.
      Seat is cracked but still comfortable.
      Happy to answer questions or take other pictures.
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get an engine swap.
      Thanks,
      John
    • wh315-8
      By wh315-8
      The RJ58 was the big hit for spectators this year at my local festivals here in Carroll County OH.
      the children loved getting their pictures sitting on it, then they discovered the bicycle horn under the steering wheel. It’s always a joy even in parades. Just love showing off part of my collection every year and hearing all the stories from those that had WH in their lives at one time. Can hardly wait to get to retirement so I can get some of my other models back to their glory in working order and be able to attend other shows/festivals throughout the year. My fellow tractor enthusiasts always know when a spectacular starts asking about WH, they point in my direction. I study up on the history of the different models and always intrigue those that didn’t know much about how WH came to be. This website is one place that has helped me learn so much about the WH history and I thank you for sharing your knowledge that I am able to pass on to keep WH alive and well.
    • BrianStasC-101
      By BrianStasC-101
