rustyoldjunk 127 #1 Posted August 22, 2008 just curious what if any pans interchange on kohlers. Share this post Link to post Share on other sites
TT-(Moderator) 1,188 #2 Posted August 22, 2008 There are basically two different oil pan styles for K series Kohler big-block single cylinder engines. The eared blocks will take the large pan, (long rectangle shape - bolts down through from the top) and the earless blocks must use the small pan. (more square - bolt up through from the bottom) You cannot put a large pan on an earless block (without making an elaborate adapter plate) but in some instances, a small pan can be installed on an eared block. (JD used this configuration with some of their models - the ears on the block are where the engine mounting brackets were fastened) 10 thru 16hp (and the K-361 18hp OHV single) are dimensionally the same at the pan rail, so the majority of the pans will interchange. Share this post Link to post Share on other sites
rustyoldjunk 127 #3 Posted August 24, 2008 thanks TT,thats everything i was looking for. Share this post Link to post Share on other sites
