JamesC-120
wheel horse wagon
JamesC-120
I was wondering what size tire should be on a wheel horse wagon 1975.
Thanks
rmaynard
It depends on the model. Which one are you asking about? If it's a tub style 5 cubic ft dump cart, the size is 4.80 x 8.
JamesC-120
It is a 4 wheeled wagon and the problem is the tires are hitting the frame when it is turned all the way. The block that is welded on to keep it from turning to far is not warn
Edited by JamesC-120
groundhog47
I know this isn't an answer, but you can look at the picture of some in manuals>implements>others. Unfortunately the size of tires/wheels is not listed.
Kelly
Pretty sure the 4 wheel wagon uses the same tires as the tub cart 4.80x8 see if the wheels are on backwards with the long part of the hub facing out instead of in??
JamesC-120
The long part is facing in but it still hits.
