dstriker
how to read my onan model number
dstriker
I don't know what year my onan is or how to read the model/spec number
My model number is p216g-I
Spec number is. 10976c
Serial number number is f893564666
Thanks to anbody that can help me the people on here are very knowledgeable about these mowers and motors
Martin
simple search (google) came up with a post from sparky on model/spec numbers....
heres 3 with your spec number
R1-16O802 1990 316-8 Garden Tractor 8 Speed Onan P216G-I/10976C
31-16O802 1990 416-8 Garden Tractor 8 Speed Onan P216G-I/10976C
41-16OE01 1990 416-H Garden Tractor Automatic Onan P216G-I/10976C
thread is here.....
should be able to determine the year by using the serial number and comparing it to others close that know what year they are. more google searching with close numbers should get you there......
maybe somebody with models that use the same engine could post there serial numbers and year to get you close.
Edited by Martin
Martin
just found this...........
http://www.smokstak.com/forum/showthread.php?t=36264
so if we use the guide in the first line your serial number decodes as
f893564666
MYYxxxxxx
f= June
89= 1989
Onan serial numbers include a build date (MMYYxxxxxxx)as the first 3 or 4 numerals or in some cases a letter for the month (A=Jan, B=Feb etc)and then 2 digits for the year (MYYxxxxxx).
Martin
now if you go back to the list from sparkys post, only 1990 and 1991 models had the C at the end of the spec number......
the engine was made in 1989 and it was installed in a 1990 or 1991 tractor......
the last 6 digits ( 564666) would narrow it down further....
Edited by Martin
6bg6ga
Ok, I have one for you
model and serial
B43E- GA016/4260B
H853  921992
boomers_influence
6bg6ga
the B 43E is listed as a STOCK engine, 16 H.P. ( not made for a specific application )
it has a 45BB crank 1 1/8" dia. X 2.74" long.
it was built in aug 1985.
thank you. boomer ( the used onan engine parts guy, also NOS and new )
6bg6ga
Thank you.
Is the 921992  the serial number?
Is it electronic ignition or points?  Just curious when they went to electronic.
Edited by 6bg6ga
redo
redone
Guys. I am searching for a Onan engine rebuilt kit for 20 Hp seriel Number 6883 476680 220G 10541B
Rods 0.10 or 0.20 under size. pistons 0.10 under. oem gasket sets.
whom would you recommend as a good parts wear house.
Thanks
Bill
onanparts.com
Thanks
Bill
Hi,
we have .010 and .020 undersize rods in stock for your P220G here:
https://onanparts.com/index.php?main_page=index&cPath=1_4&sort=20a&page=2
.010 oversize pistons here:
https://onanparts.com/index.php?main_page=product_info&cPath=1_2&products_id=806
Gasket kit here:
https://onanparts.com/index.php?main_page=product_info&cPath=1_7_19&products_id=6
All OEM Made in U.S.A. :)
