engine563
riped it out
engine563
hi i have a charger 7 and riped the trans out of it and i was woundering if any one has had the same proble and if they put a new one in or if theres a way to fix it with out a new trans
Kelly
I guess I'm not sure what you mean you ripped it out??? you break it or did it stop working???
groundhog47
  :WRS: and to understand more :wwp:. If you need one for change out/swap several members sell them, and I believe we have members that repair them for others. If it's ripped out of frame attachment, there are several posts on repair. If frame is twisted and trans attachment broken/ripped/torn frame replacement may be an option. A pic is really good for explanation.
It looks as if WH only had 2 Chargers (V7) and both used the Eaton Auto, so do you now aside from above is it the actual gearing or hydraulic portion. Some one am sure has expertise in that also, I do not know squat about Eaton :confusion-shrug:, good luck with endeavor.
Edited by groundhog47
AMC RULES
...or simply...removed it from the tractor?  :eusa-think:
