Ken B
A few more ponies under the hood....
Ken B
I got home from work today with a little extra energy so I decided to do a little work on my son Coles Burban. Since I can't find any of them NOS blue electric start motors I decided too fab up my own.  Just as I was gettin started and tryin to come up with some idea's I glanced up at my work bench and there it was.... the hell with puttin electric start on a k91 that is a little tired. On went this k181 with electric start. All it took was four new holes and a few other mods and that is it. No hood hackin etc. Its a tight fit but it fits and nothing hits. I should be blastin around tomm with it if all goes as planned. Once any bugs are worked out I'll pull it off and paint it up.
Edited by Ken B
stevebo
I knew that would be sitting under the hood of a roundie at some point! Looks very nice! Now you can change the pulley size too!
Ken B
I think I'm about as small as I want to go on the pulley, but we'll see!
stevebo
more ponies you may want to go smaller...
Electro12WH
Wow!!! Keep the front end down!    :woohoo:
fireman
NIce Ken! Now put a smaller pulley on the transmission input shaft and it will really rock  :auto-layrubber:
Fun Engineer
More Power :happy-jumpeveryone:
VinsRJ
Now thats going to have a nice sound with the long tail pipes!
Jake Kuhn
Very cool ken! Hope to see a video of when you get it going!
Vinylguy
Nut Roaster on steroids!! You may need a warning sticker for driver protection.
How about a belt buckle fan to blow the hot air away from the driver
rwilson
Looks good Ken
Ken B
I've been running a 3 inch rear pulley on it this summer and its just fast enough, I don't feel like tearing it up. I'm going to have to come up with an idea for a belt guard as this one will have to be modified and I'd rather not do that to this guard, I don't want too mislead anyone here, there are lots of little mods that need to be done with this swap, no rocket science, just time consuming. I have at least an hr and a half into just the air cleaner housing mod....I did fire it up tonight but I don't think it will be driveable till Friday at the earliest.
stevebo
I am thinkin you will have it done Thursday.... lol Take pictures as you go of the mods !! If you want to run a muffler I have a small stack you can have
woodchuckfarmer
A big block burban ...I like it and nice job....
Ken B
Well Steve, we are both wrong! I got it to the point tonight where I could take it for a burn down the road. It no doubt has more giddy up. I nailed it a few times and managed to cook the belt. The exhaust is the same exact setup I had on it before with the K91. It doesn't rack off like before and quite simply, it don't sound as good now! I may come up with something else that might have a better sound...Trial and error. I still have to take care of a few odds and ends, longer battery cable, battery hold down etc. How nice it is to sit on a nut roaster and turn the key. With all that said.... Well lookee, its # 3000 for me!
stevebo
ken-Congrats on 3000 posts !! Always a interesting read for sure. The tractor looks awesome. I have a new muffler "Stack" you are welcome to try. Maybe run that under the tractor?
Ken B
That might work Steve, It needs to be muffled a little for sure.
stevebo
it should work pretty good since it is not all that wide...come and get it
SousaKerry
"I should be blastin around tomm with it if all goes as planned. Once any bugs are worked out"
Poor Tomm does he even know your coming?
squonk
Rats! I was hopin for a K-341!!
stevebo
Ken,
I got one of those too if you want to try for a big block !!
Ken B
I think a 16 would really take some cuttin to get it too fit and this Burban is probably to nice to do that to. I might bring up the idea to Cole of puttin stock tires (snow treads) and rims back on, I always liked the sleeper look!
stevebo
Got a set of those in stock too...
MrTrimmier
Well executed. Looks like a stock setup. Dr. Mike prescribes a nose weight!
MT
Ken B
The plan all along was to get the engine on, fabbing done, test drive and then pull the engine back off and paint it. I pulled it last night and painted the block at home. I took the tins to work and painted them with my hvlp with Resto Series. I got home from work today and had it all done within a few hrs. Cole finally got to take his test drive and he's diggin it! What does he like about it the most? Electric start! I used a belt guard off a tractor I got from Vin, I modded it too fit this engine until i have time to make a new cover from scratch to look more like the original cover. I also redesigned my foot throttle from the one previous. Its done! (for now)
