Digger 66
Raider 10 Rear Lift ?
Digger 66
I'm looking for anyone who may be willing to share pics of the rear lift mechanism on a Raider 10
This how mine was when I got it , I see it's fitted with some kind of cable housing running from the rear ( which would be to raise & lower the hitch ) but the hitch hardware is fashioned in such a way that it neither moves up or down . Or was there an additional piece that's missing ?
Here are some pics of the rear as it sits :
Any help is welcome & thanks in advance , -Gene .
Hitch & bracket :
I assume there was some type of cable fed through the tube ( arrows ) & some type of lever near the shifter(s)
I don't see any mounting pivot for any lever that may have been there ....
Digger 66
Or was the current bracket simply removed and the desired attachment put in place when ready to use ?
stevasaurus
Check out the last picture in this link...the cable attached to the lift arm and goes through the tube. :)   I can't believe I don't have a picture of mine and it is at my Mom's. :bow-blue:
check the pictures in this link...
Edited by stevasaurus
bean
  • what you have on there now, is a trailer hitch. it is stationary. the slot style hitch and the later ,clevis style hitch mount in the between the trans and present hitch.
Edited by bean
Digger 66
That's the pic I was looking for , THANKS ! ^
The cable lift system ( to my untrained eye ) just doesn't seem very sturdy ?
What types of attachments is this designed to be used with ? Bottom-plow ?
Dual Drive Horse
I have the sleeve hitch, and it will lift a single furrow plough easily. When I eventually make a two furrow then I will probably fit a small electric winch to lift itArdinglySteamRally11_zpsc5e30351.jpg
Edited by Dual Drive Horse
rwilson
Hey the one on the right is mine!! It doesn't look like that now though.
papaglide
The cable will work with a single bottem plow, harrow, disc and all of the assorted stuff. I have plowed up a 15 by 75 foot garden using my B 80 and a 8" single bottem plow attached to a slot hitch which was lifted by a cable. Its not a solid link like a cub but its just as sturdy.
