ralphxj
New guy from Ohio with an 875
ralphxj
New guy here from Austintown Ohio. I'm a Jeep guy, however I'm currently without a Jeep or project and the shop seemed too empty. I found my next project, my grandfathers original 1965 Wheel Horse 875. Grandpa bought the 875 new and used it until he passed away in 1992 (I was 12). After that my uncle and grandma used it for a couple more years, then got a newer mower. My dad brought the mower to our house shortly after that and we used it (along with a newer wheel horse dad had) to mow my parents 2 acres. I spent MANY MANY hours on this mower as a kid!! It was kept under roof its whole life, so it has very little rust on it.
It still fires right up and runs with no issues except a starter/generator that is sparking at a loose terminal (already have a rebuild kit). The mower deck is SHOT, its been repaired many times over the years and is too far rusted at this point. The plan is to do a mild restore project. I plan on painting the main sheet metal and clean everything else up.
Other then the rear tires, its all exactly how it was when Grandpa used it!
post-11203-0-12668200-1374708730_thumb.j
post-11203-0-96721000-1374708730_thumb.j
post-11203-0-89174700-1374708731_thumb.j
post-11203-0-58797400-1374708732_thumb.j
post-11203-0-30150400-1374708733_thumb.j
Edited by ralphxj
Sparky
:WRS:
  Fixing it up would be a great tribute to your grandpa.
Mike............
AMC RULES
If it was me, I'd just clean that one up as best I could, without a complete repaint/restoration.
Maybe powder coat the rims and new tires...
it would be a shame to strip the generations of use by your family off of that tractor.   :twocents-twocents:
                                              :text-welcomewave:
groundhog47
Hey, welcome to :rs: , great one to start with as has family attachment. Follow ya on the mower deck, wish they were available at a decent cost still, but good ones show up often up that way. Good luck on your restoration!
ralphxj
                                              :text-welcomewave:
I thought about it! I've gone back and forth, but I'm hoping to take it back to close to how it was when Grandpa bought it. I'm not big on having orginal paint/rust/patina like some people.
Jake Kuhn
Welcome to red square!
AMC RULES
When you redo it can you save all that (original  :wh: paint/rust/patina) stuff for me?   :handgestures-thumbsup:
KC9KAS
:WRS:  and thanks for the photos.
Kelly
:WRS:
JC 1965
Hello and :WRS:
VinsRJ
Welcome to RS!
Amanda
Welcome to Red Square   :)
can whlvr
:WRS:
ralphxj
Thanks for the warm welcome!! This weekend I need to install 2 more lights in the shop and setup the new plasma on the plasma table, then I'll hopefully rebuilt the starter on the 875! Very excited to start this project!
dyt4000
Terry M
Nice 875! :handgestures-thumbupright: ...and welcome to the :rs:
  • Similar Content
    • dannyo
      By dannyo
      Hi all.  I am new to the Wheel Horse world and I have a question about attaching a tiller to my 875 before I start spending money.  Based on what I've read so far, it sounds like I can use the RT-366 tiller without having the 8-3311 PTO assembly, is this correct?  If so, does the RT-366 belt attach to the hydrostatic motor if there is a double pully (#6887) installed?
    • D_Mac
      By D_Mac
      Picked this up today because I wanted the deck for my 875. The 875 has no deck so I figured this one is better then none at all. Question is what do I do with the rest of it??? 875, was told the engine needs rebuilding. Been sitting in a barn last 20+ years. Steering wheel is broke. Both front tires are shot and coming off the rims. Original paint. Plow needs the arm to turn the blade. Its repaired in a fixed position. Worth more in parts or as whole? Not sure I want a big project. What do you all suggest???
    • KC9KAS
      By KC9KAS
      My 875 is missing the small spring that is attached to the cam/neutral plate.
      The part number is 1230 and NLA.
      Anyone have one or know the dimensions of the spring?
      Thank you!
    • KC9KAS
      By KC9KAS
      ISO of hydro motion control lever bushings.
      These appear to be parts # 5666 (nylon) need 2, # 5983 (Nyliner) need 2, # MW2195 (bronze) need 1.
      Please PM me here.
      Thanks in advance.
    • admin
      By admin-(Admin)
      1 page 196.25KB
      1 page 82.24KB
      Dated February 17, 1965
      232613 Kohler belt nla Use 231605
      232613 - Gates 7320 .41"x32.58" 36 degree or Napa 25-7320 .41"x32.58" 36 degree
      231605 - Gates 7315 .41"x32.08" 36 degree or Napa 25-7315 .41"x32.08" 36 degree
      1964 model 854
      1965 model 855
      1965 model 875
      Starter/generator belt
      Kohler 10hp, 12hp - 235262 (7345 Gates .410" x 35.09" 36 degree) (25-7345 Napa .410" x 35.09" 36 degree)
      Wheel Horse 1593 (3L x 34.4") - nla (Gates replacement 6735 3/8" x 35" 38 degree)
      1964 model 1045
      1964 model 1054 - Not in PSB - Wheel Horse # 1593 nla {3Lx34.4"} - Gates 7340 .410"x34.58" 36 degree or Napa 25-7340 .410"x34.58" 36 degree
      1965 model 1054A - Not in PSB - Kohler 235262 replaces 235528 [.41"x35.09" 36 degree] - Gates 7345 .41"x35.09" 36 degree or Napa 25-7345 .41"x35.09" 36 degree
      1965 model 1055
      1965 model 1075
