swampman
244H,TRANS PROBLEM, need some ideas!
swampman
Hi Guys, I have this 92(?) 244H I have been using since May of last year and it just seems like
it gets slower all the time.
I would think if the Drive Belt were slipping I would hear it or see signs of it coming apart.
Last year when I started using it the Trans oil was green in color,now it is dark.
I wanted to change it but I can't find 20w which the manual specifies,and then there's the therory
about not changing Trans oil unless you have to.
Should I change the Trans oil?,if so..what should I use?
Could the Trans be slipping internaly?
Can anyone shed some light on this?
thanks in advance!
steve in PA
244H
B-100
Edited by swampman
swampman
ANYONE?....
Jeff-C175
GREEN?  What's it smell like?
I wanted to change it but I can't find 20w which the manual specifies,and then there's the therory about not changing Trans oil unless you have to.
Manual calls for 20W ?  as in 20W SAE straight weight motor oil?  (sorry, not familiar with your machine).
I don't think I would buy any cockamamie theory of 'not changing Trans oil unless you have to.'  What does that really mean anyway?  If the manual for the machine specifies a service interval for the trans oil, then you 'have to'.
rmaynard
According to the official Toro/Wheel Horse 1956-1999 Lubrication Recommendations, Drive Belt & Mower Blade Usage Charts, the proper fluid for your 244H is 1 quart of SAE 30 API Service SG, SH, SJ or higher oil.
Drain it and replace it. What harm is it going to do? I don't think it will make it any worse. :)
Jeff-C175
Just found a manual for the Eaton 7 series trans... and surprise to me it says:
Oil changes - not required
Which in my opinion is crazy... but they're the manufacturer, who am I to second guess them?
Anyway, if you had GREEN fluid in your trans last year, it sounds to me as if someone put in the wrong fluid.  SAE 20W premium motor oil should never be GREEN!   I sure hope it wasn't anti-freeze! :ychain::laughing-rofl:
Edited by Jeffpicks
boovuc
Eaton 7's are light duty and the pump is known to fail. For the price of a quart of oil, (actually less than a quart since you won't get it all out), you have absolutely nothing to lose but time if you get the same result afterward. We aren't that familiar with the 200 series tractors although there are members that have them and may chime in. Possibly asking for advice on the main forum page will get a better hit from 200 series owners. Your oil may have over-heated either because of a fan/cooling issue or a pump issue continually doing blow-by.
Good Luck!
  • Similar Content
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • BrianStasC-101
      By BrianStasC-101
    • FAST41
      By FAST41
      I am new to this group. I have my sons collection of Wheel Horse tractors that are definitely rare models. He still has one to pick up that’s dual wheel and was purchased from Peabody Coal Co. This is the perfect site to get involved with. The best advice comes from folks that are hands on.. had to be their own machine shop. Nothing compares to the knowledge in this group.! But my first topic is this 19hp Craftsman INDY 500 limited edition model. I was reading a topic on here about the 18hp and 20hp models, but cannot find a single replica of this tractor on ANY site or e-bay. We live near central Ohio, so I’m assuming it’s a regional release.The Briggs engine lobes like a medium cam in a V8. We thought it was an intermittent miss, but it’s not missing a bit. The engine is the strongest riding tractor I’ve ever operated. It will literally cook the deck belt in high grass before dragging the engine down. Very wide and lower to the ground. I never got the size, but the rearend is all tires.! Looks like a dragster from behind.. almost  gives the appearance of shortened axle tubes in a hot rod. Just wondering if anybodys ever seen this particular model. My next top is will be about the C160 total hydraulic Wheel Horse he just acquired. Claim they were specially made for snow removal.
    • Wendell
      By Wendell
      New to the forum, but not to Wheel Horse. I just bought a 314-8 on the gear shift pattern there is what Toro calls a spring shift control, my 312-8 doesn't have this The 314 is a 1999, what was the purpose for this. Thanks.
    • Bobbi Barroso
      By Bobbi Barroso
      Missing lift rod. Anyone know where to buy one or the dimensions to make one?
