Countdown To Christmas!
Digger 66
Diff / Trans lube ?
Digger 66
Tearing into the trans /diff lube change on my Raider 10 & have a few ?'s
1) the diff / trans seems to be one casting so should I assume they " share " lubricant ?
2) From the rear , there is a drain at the bottom , a couple inches up on the clutch / brake side there is what appears to be a level check / fill boss with plug
3) there is a fill under the seat with a dipstick .
Which one is the level check ?
Also is any GL-5 lube OK to use ?
Fill & check here ? or ....
Here ?
Is this lube OK ??
Thanks for any info , folks .
-Gene
Edited by Digger 66
stevasaurus
Yes, the differential is in the trans case with the rest of the gears.  I would use the dip stick...but it should be the same level as the side check level plug.  Yes, that oil is OK to use. :)
Digger 66
Excellent !
Thank you , Sir .
woodbird007
Piggyback question. If you switch to synthetic trans lube do you have to be extra fussy about flushing out the transmission case. If so, with what?
Thanks
