SomeGuy892
Cause of Broken Drive Belt 257-H
SomeGuy892
Hello,
I have a Wheel Horse 257-H that I replaced the drive belt on about a year ago.  The replacement belt I used was not the Wheel Horse part but a after market drive belt that was a pretty close match in size.  I noticed the replacement belt slipping a bit a few months after I installed it.  I could smell it when hauling loads or going up steep hills but it didn't affect operation so I didn't worry about it.  Well this summer it broke and what I am wondering is if the cause was more likely premature wear from the heat caused by slipping or if it is more likely the stress from the heavy loads of firewood I towed with it this spring.
I like to haul heavy loads and since I am replacing the belt with the OEM part I am hoping slippage wont be an issue.  If so can I push the drive belt as far as the hydraulics and motor can go or should I always expect to find out that I pushed it too far with a drive belt failure?
Thanks,
Nick
daveoman1966
109428 is the belt and Toro has it for less than $30. Stay clear of after=market belts as they are not geometrically identical and, accordingly, will not mate perfectly to the V of drive pulleys....that's why the heat leading to premature south-bound. Secondly, IMHO, they are of lesser quality and not designed for the backward-flip flex loads.
About 3 years ago, I had to...for the 1st time... replace the drive belt on my Bronco 14. I bought that machine new in 1972. I'd say that the original belt lasted long enough...38 years or so.
SomeGuy892
Believe it or not they wanted 80 dollars for the same belt last year.  I got it installed and all seems to be well so I am just going to use it and hopefully no need for replacement for a while.  Also while on the topic of drive belt replacement is there a trick to adjusting the electric PTO?  Mine is up and working but want to make sure I don't get premature wear.
leeave96
+1 on original belts.
Also, be careful hauling heavy loads. That tractor's tranny is not designed for it - no matter what anyone says.
If you want to do some heavy hauling, even an 8 hp C series or 300 series will do the job without worrying about a tranny failure.
Good luck,
Bill
  • Similar Content
    • wheeledhorseman
      By wheeledhorseman
      Operator manual #810296R1
      4 pages 848.00KB
      2 pages 171.30KB
      Fits
      1983 B-Series and LT-Series See Product Service bulletin
      1984 B-Series and LT-Series
      1985-1986 200-Series
      For vertical shaft 200 series models 1985 onwards but was also used with 1979-80 B series models (supplied with different lift rod) Fits for example B-165 or 216-5.
      Dozer 1983 42in model 06-42BB02 Complete
      1983 serial numbers that have shown up for the 06-42BB02
      19345
      20452 - Build date 1983 3259 September 16 Friday
      20551 - Build date 1983 3259 September 16 Friday [259] Guess
      Dozer 1984 42in model 06-42BB02 Complete
      1984 serial numbers that have shown up for the 06-42BB02
      23294 - Build date 1984 4193 July 12 Thursday
      Dozer 1985 42in model 06-42BB02 Complete
      Dozer 1986 42in model 06-42BB02 Complete
      Link to service bulletin
      http://www.wheelhorseforum.com/files/file/469-wh61-90-315-snow-equipment-1982pdf/
    • Willhaven
      By Willhaven
      Does anyone know if you can make a 211-5 Single Blade (30”) a mulched or side discharge? I only have the bagging system but would like to mulch (if possible) with my new Oregon Gator Blade.
    • Willhaven
      By Willhaven
      Has anyone tried adding/installing deck wheels to a WH 211-5SB? If so, is there a specific make/model that would work best on this tractor? My lawn doesn't have the most level of surfaces, so adding wheels will save me from multiple scalpings (I think).
    • Willhaven
      By Willhaven
      Trying to find the part numbers for my 1989 211-5SB air filter and gas filter. I was able to find the old part number for the mower blade (111144) which I cross-referenced with the Toro replacement but can't find filter info.
      Thanks!
    • Willhaven
      By Willhaven
      My second post here, and apologies for a potentially amateur question. I've had my WH for a couple of weeks now and am looking for a manual, video, and/or someone's help here on how to remove the deck. I need to confirm the size of the blade (and replace it!)
      Thanks!
