MrTrimmier
701 is finally home!
MrTrimmier
After almost 2 years after purchase, we drove from Beaufort SC to Winston-Salem NC to claim the 701. The seller was supposed to bring it to Myrtle Beach and save us a bunch of driving but it never happened. Oddly enough, when we were about 20 minutes out from his place I noticed a trailer in front of us with a restored 701 and another round hood sitting side by side being pulled down the road on a red trailer. As we passed it occurred to me it had been 30 years since we had sold our 701 and it's implements, which was the last time I had actually laid eyes on a wheel horse.
Having said that, it was an uneventful trip back through my home city of Charlotte NC back to Beaufort. The 701 is in very sad shape, having set outside for obviously decades. The shifter is sheared off above the pivot. The L steering arm to the spindle is broken off where the roll pin goes through, and the belt cover is missing off of the Kohler. The seller told my wife "everyone" wanted the mower deck so I suspect the belt cover was a quick sale item to one of the lookers.
The wheels and seat pan are rusted out, the mower deck is holed and pitted. Other than that it is a complete 701 replete with vintage battery and liquid varnish in the tank and sediment bowl. I have some other wheels to fit, so that will be step 1 followed by vacuuming the leaf buildup around the shifter and in the tool tray. The 7 horse spins, but I didn't get too aggressive without some lubricant in the cylinder. It appears all the hardware is now melded with it's respective sheetmetal. Some PB blaster will be in order prior to any attempt to remove the lugs or hood bolts...
Guess it's time to pull it down into chunks and try my hand at some electrolysis tank immersion...
I bought a new dash, throttle cable, muffler, rear hubs and adjustable implement lowering device while in the Middle East...
Good Times Ahead!
Sparky
Looks like you have your work cut out for ya! Good luck ith it.
Mike.......
rmaynard
Looks like you have your work cut out for you. There seems to be an awful lot of oil all over the pto side of the engine. I am curious where that is coming from. I think that I would forget the e-tank and go for a sand blast cabinet on this one.
All great minds think alike Mike.
AMC RULES
You found   :wh: 701 parts in the Middle East?   :scared-eek:
stevebo
I see the belt guard is missing on this one. I would try a really good cleaning with a pressure washer and then wet sanding the tins with 1000 grit and see if there is any paint under that surface rust. You may be surprised.....
MrTrimmier
I'll clean it up as best possible and see if it wishes to obtain operational status. Been hunting ebay for a steering arm to no avail. Anyone have one to sell???? L side tie rod to top of spindle??? And a shifter if anyone has one as well. The rear axle turns as evidenced by the thing trying to roll off the trailer with 4 flats after we got dudes Bobcat running and loaded it up. I had mentioned the electrolysis tank to see if that would help in sheetmetal hardware removal. I'll start with some PB blaster then move to 50/50 trans fluid and acetone if that doesn't work, followed by some heat!!! Might just pull the hood and motor and drop the whole mess in a molasses tank. The hotrod guys seem to have good luck with that method as well!
Mike
Edited by MrTrimmier
stevasaurus
That deck is the original deck for that horse...only year they made that deck and it went on the 701.  Don't lose it...it is on the rare side and is sought after.  Notice the wheels are on the inside of the deck.  They would get a little tangled with grass clippings so for 1962 the wheels were moved to the outside. :)
MrTrimmier
Yep, 3661 deck is it? There is a legible decal but it's been a couple of days. No progress to date, she's still on the trailer!
Need a steering arm! The manual calls out P/N 3919LH. Also, what size roll pin holds it on plz!
The shifter stick is P/N 4215
TIA
Mike
buckrancher
looks like one I would miss with :banghead:  :deadhorse:
MrTrimmier
YOU ROCK BRIAN!!!
stevebo
Shoot me a pm to remind me to see if I have that part. Away from home right now
MrTrimmier
BTW I'm willing to trade off the deck I have for the other model if serviceable. Our old tractor had that deck and a silver frame/axle, so that's the route we'll go with this one come time for paint. Almost forgot, need a seat pan as well!
Mike T
Beaufort SC
Wheel Horse Kid
Looks like a great project and most of it seems to be there! Would love to get my hands on a 701 someday when I get some cash. Good luck with it!
OnlyRedInMyShed
I went to see this tractor awhile back.  Although it's a pretty big project i'm glad it found an owner who will give it new life.  Someone needed to save this horse because the owner had too many projects and would have left it for dead. :deadhorse:
buckrancher
Mike
I may have some of the parts your looking for. pm me a list
all the roll pins should be 1/4" doubled up (1/4" with a 5/32" drove inside the 1/4")
Brian
MrTrimmier
Here is my parts needed list!
I need the following for a 701.
1. L steering arm (tie rod to spindle) # 3919LH
2. Shifter rod # 4215
3. Seat Pan (round or square)
You can emai me at mrtrimmier@gmail.com
Thanks
Mike Trimmier
Beaufort SC
BPjunk
I would not trade off the RMR 3661 mower deck as that mower deck was unique to the 1961 model 701. The 1961 model 701 is one of the hardest Wheel Horse tractor to restore due to the many parts that were not found on the mid engine models and later 1960's model round hoods but this makes a restored 701 very rewarding to own.
One of the rare parts found on just a few 701's is the 1345 and 1346 hood thumb screws that had a step cut into them, my 701 had only one of these and Tony Beugger from Quebec, Canada has them on his 701 that he had at the Annual Wheel Horse Show this year. I will post a picture of this type of thumb screw when I can.
Good Luck on your restoration.
Wild Bill
Richmond, VA
MrTrimmier
Hand wash, Pickled the engine (turns/good compression) and some new shoes!
Regards
Mike
  • Like 5
Jake Kuhn
Looks much better cleaned up!
MrTrimmier
just a green scrubby pad and some dawn after an all over spray oil soak. bolts are starting to move! around the shifter and the toolbox are still pretty crusty. hood came out decent!
Mike
Wheel Horse Kid
Wow! What an improvement from the first pics! Keep up the great work!
MrTrimmier
Kudos to Buckrancher for hooking me up. Shifter and some steering arms. CHEERS!!!
Mike
Ed Kennell
Nice save.
AMC RULES
Nice progress so far.   :)
Hodge71
Looks great compared to what she started out as!!!
  • Similar Content
    • buzzard440
      By buzzard440
      1961 701 for sale complete and original w/ mower deck. Runs but needs TLC.
    • oliver2-44
      By oliver2-44
      This one was on Marketplace for quite a while with a hefty price tag.  I ask if he was flexible on price, Nope.  After a quite a while longer same question before I made the drive.  Come on up, maybe we can make a deal.  The rest is history, I didn't steal it, but I'm happy with the deal!
      Ya I know you want pictures, but there a little more interesting back story.  His granddad's business was Nicholson Machine and Equipment and he was a Wheelhorse Dealer in the 50's and 60's in Paris....., Tx  that is!  He sent me this picture of the glass window from the door to the business that he has framed.
      He also wrote me a short note about his Granddad's business.  So after his he passed, his dad gave the tractor to him. he's had it for quite a few years and said it's always been garage kept.
      So if a Dealer owned this for his own use and never sold it, and then it passed to his Son, and then Grandson, that would technically make me the 1st buyer,
        Ok so on to some tractor photo's
      beautiful double pulley belt guard front and center.  It starts with a spray of gas in the carb, but doesn't stay running.
      All there, nice and original, you can see a weld repair on the front of the belt guard,
      Here's the serial number @gwest_ca
      The plastic dash is intact and not cracked!
      My 1st old style split key.
      it still has the orignal Silverton Ags. They hold air, but their so hard they probable don't need any.  I wonder if their hard because they might still have calcium chloride in them???
      The hitch pin isn't frozen and the lift cable even works.
      Interesting decal plastered across the front of the hood.
      aluminum gas tank is fairly clean.
      Hood bottom tab has been repaired.
      topless view of the engine, needs a bath. The front tires are original and hold air, but have some splits across the thread.
      Homemade choke and throttle cable bracket.  The base of the engine has wet oil, so i suspect it needs some gaskets.
      Both axle seals are dry, but the input shaft and brake shaft seals leak.
      I've learned if the top of the transmission is filthy oily, it probable means theirs water in the transmission that has floated the oil out.  This one is clean so hopefully that's a good sign.
      Started some maintenance and a beautiful sight, not a drop of water, just black oil.  It shifts through the gears nicely so it will be interesting to see how it runs/drives.
      I'll gradually go all through it with my checklist.  701 Minor Overhaul Checklist.ods
      Then have to decide if I rub it down with linseed oil like it is, or buff with some steel wool or wet sand to bring a little more red out, then oil.
      How would ya'll put your finishing touches on it?
      I'll update this thread as I do maintenance on it and get it running.
    • wh315-8
      By wh315-8
      So just picked up a 701, obviously the engine isn't right. I have a 7hp Kohler to put on and will put B&S on my Speedex. Anyone ever seen a post come out on the right from the rock shaft? It rotates with the lift handle and has no holes in it. It was done up well, almost looking factory.
    • chompinthebit
      By chompinthebit
      Hi all,
      i bought this 1961 701 in fall of 2018 and restored it. I completed it in fall of 2019 and I wanted to show some pictures of before during and after I got it done. I did my research and tried to make this tractor as close to original as possible. The few exceptions are tires, wiring and the steering support. Not a perfect tractor but sure is nice enough for me.
      all stainless hardware
      Rustolium stops rust Primer
      Rustolium Regal Red enamel paint
      powder coated wheels and seat
      Glenn Pettit Reproduction dash
    • T-Mo
      By T-Mo-(Moderator)
      1961 701s
