Countdown To Christmas!
Zgt500
Pulling tractor transmission (snowmobile engine)
Zgt500
What transmission should I use on a pulling tractor with a Polaris 1000 engine on it?
AMC RULES
:wwp:
:WRS:
stevasaurus
If you are going to use a wheel horse transmission...the strongest is the 8 speed, 8 pinion with 1 1/8" axles. :)   I think # 5091.
BTW...Welcome to Red Square    You may want to check out our "Puller" section on the main page.
Edited by stevasaurus
baerpath
This one uses a WH 8 pinion trans I forgot what sled engine he has in it, and now it's Artic Cat green
Zgt500
That's just the stock 8 speed right?
boovuc
Well yes and no. There are two very different 8 speed trannies plus a couple older posi-rears sprinkled here and about. The very best rears are the 8 pinion/inch and an eighth rears. Look for the inch and an eighth axle diameter as opposed to an inch diameter axle.
Zgt500
Ok, if I can find one, should I rebuild it?
baerpath
Rebuilding is going to depend on what shape it's in when you get it. Where are you in NY ? Are you going for a modified or a repowered tractor look ?
stevasaurus
For what you are building, I would at least open it up and take a look.  Not hard to do and plenty of help here on the site.  You may want to consider sending a PM to Mike Biser (racinfool40)...he may have the transmission you are looking for, and it may already have been rebuilt/checked out. :)  He picks them up, fixes them and sells parts.
smoreau
C81 is one of the tractors that have this trans
baerpath
 We don't go into them until they break.
But most of us have 2 or 3 spare trans so we can swap out when needed. I have two under the bench ready to go for backups and some still in tractors just in case. We have snapped a couple axles and hubs too.
jdpuller
will your rules let you run automotive trans and rearend?
Edited by jdpuller
Zgt500
I dunno, I haven't ran it yet
SousaKerry
Wow bearpath I think you found the stress riser in that input shaft....
If you keep breaking keyways out like that you may want to consider using a trantourque or similar keyless hub. Or at least a taper lock hub.
js5020
Anyone have a pic of these keyless hubs installed?  Seems like an alternative to repair a bad axle without getting into the transaxle, Im thinking it would be much easier to bore the hub if one of these devices would work?
SousaKerry
Here is the website
http://www.fennerdrives.com/trantorque/
baerpath
That was the axle split the hub also. Still not sure why it did that.
