skrusins 128 #1 Posted June 29, 2013 Hi, I've been doing a search in RS for a p/n for a gator blade I found several different numbers. Oregon 96-303, 90-714, 90-643, I would like to know if anybody knows the correct number. Thanks in advance Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #2 Posted June 29, 2013 The only one I see on a list I made is the 90-643 which replaces Wheel Horse/Toro blade # 106077 and 106636 3-blade set that fit the side discharge decks. Have a 3/4" round hole. (Oregon # 91-805 13-27/32in. regular blade) (Oregon Gator Mulcher # 90-943 13-27/32in.) (Oregon Gator Mulcher 3-in-1 # 90-643 13-27/32in.) What is the original Toro blade number for your deck or the deck model number? What dimensions are the holes? 3/4" round or 5/8"x3/4" double-D shaped hole? Garry Share this post Link to post Share on other sites
hbrooks49 12 #3 Posted June 29, 2013 The gator blades that came off my 42 inch rear discharge deck were listed for a Dixie Chopper. Oregon blade number 90-714. They measure 14-1/2" diagonal and have a 3/4 inch center. hole. Hope this helps out. They worked fine and I plan to sharpen them and use them as spares. In tall grass the regular blades seem to give me a better cut. Share this post Link to post Share on other sites
skrusins 128 #4 Posted July 1, 2013 Thanks I checked 90-714 on Oregon's web site, and it's not available. Evidently nobody else is using gator blades anymore. I have had good luck using them in the past on all the equipment I owned. Share this post Link to post Share on other sites
Fordiesel69 267 #5 Posted July 2, 2013 What are gator blades? Do they improve the cut or something. Or do they just last longer? Share this post Link to post Share on other sites
