meadowfield 2,616 #1 Posted June 25, 2013 Ever since I got my GT14, it did feel hard to operate the motion control linkage... I had cleaned and greased as well as adjusted the tension on the motion lever but I could see I was pushing the lever against the action of the neutral cam. Now having had a drive around on Ians (stigian) GT14 I note that his brake pedal always returns to upright. So I had a look in the parts manual and I can see there is a spring that attaches to the neutral cam. Now I haven't had a peek inside mine to see if it's missing, but I've a hunch it is So without having to guess, can anyone help me with the length and approx gauge of spring? pt no. looks like 1230 cheers mark Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,133 #2 Posted June 25, 2013 The # 1230 should be a very popular spring and you may already have one. It is also used on the pto clutch rod of the 1977 C-120 model 71-12K801 and likely many more. https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro You can also enter a model name here now like C-120 and they will all come up. Garry Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,133 #3 Posted June 25, 2013 Believe I found a 1230 spring on my C-120 Wire .040" or 1mm Distance between hooks 1.750" or 44mm Coil OD .350" or 9mm Coil length 1.024" or 26mm 24 coils @ 1.024" = .042667" wire diameter with corrosion and dirt so it's close. Garry Share this post Link to post Share on other sites
meadowfield 2,616 #4 Posted June 25, 2013 that's fab Garry, will see what I can find thanks mark Share this post Link to post Share on other sites
wheeledhorseman 575 #5 Posted June 25, 2013 Hope the brake pedal return spring is easier to fit on a GT-14 than it is on a C120 Auto. When I was restoring the 120 I discovered that the spring was so corroded it had broken so found a spring that would do and put it to one side. When I was reassembling the tractor I forgot to put it in - big mistake as once the tractor is reassemebled and all the linkages are in place on a C-120 it's all but impossible to hook one of the ends on where it had to go. A gynaecologist might have manged it but I gave up in the end and found a shorter spring that I managed to hook onto something else. Andy Share this post Link to post Share on other sites
