timm6528 0 #1 Posted June 24, 2013 i seen a few places on this forum about replaceing brake band material from mclaster , current part # for 1 1/2 x 3/16 is 6175K813 , what glue or adhesive has anyone used and had success with? i would rather use glue or adhesive than rivets tim in pa Share this post Link to post Share on other sites
daveoman1966 3,745 #2 Posted June 24, 2013 I have used JB Weld, but had better luck with POR15. JB doesn't really like to stick to the fiberous material and POR15 soaks into it to make a pretty much permanent bond. As for the material... I used a piece of leather from an old belt. It does the job nicely and is in your closet...no need to order it. 1 Share this post Link to post Share on other sites
rmaynard 15,424 #3 Posted June 24, 2013 I have assembled dozens of them with clear silicone adhesive. Share this post Link to post Share on other sites
BPjunk 184 #4 Posted June 24, 2013 I would use a good 2 part epoxy and make sure both surfaces are clean ..... REAL CLEAN to make sure you get all the oil out from the pores in the band and brake lining. I have reinstalled a lot of old type bands this way to keep the tractor original. Wild Bill Richmond, VA 1 Share this post Link to post Share on other sites
55rj35jr 623 #5 Posted June 25, 2013 I've had good luck with Gorilla Glue Share this post Link to post Share on other sites
JC 1965 1,530 #6 Posted June 25, 2013 I have assembled dozens of them with clear silicone adhesive. Bob , I think i read in another post that you install a rivet to keep the pad from slipping. What size rivet and where do you install it ? Share this post Link to post Share on other sites
Lane Ranger 10,943 #7 Posted June 25, 2013 Like Wild Bill says cleaning of the brake band housing is the most important step. Use acetone or some other strong cleaner to remove all the oil residue, grease, dirt etc. I used two part epoxy also and it has held up great. 1 Share this post Link to post Share on other sites
