55rj35jr
GEAR NOISE
55rj35jr
I've got gear winding and grinding gear noise in my trans it shifts and works fine just the noise I drained and flushed it and replaced the oil didn't help anyone have any ideas on how to quiet it down ? or do I need to replace the trans with a different one?   thanks
can whlvr
good chance its a bearing,it needs to be replaced before it wears out what ever is riding in it(if its a bearing)could be worn gears too
sorekiwi
As Don said it is probably due to a worn bearing.  Gear whine is a result of everything getting out of alignment, usually because a bearing has failed.
If you catch it early enough a new set of bearings will save the trans.  There are plenty of threads on here to show you what is involved.
