Buda
855 resto.....sort of
Buda
Its gona be slow going as money it tight but here is my start
Tie Rods
Ran a die over 3/8 in cold rolled steel rod and got some tie rod ends at Farm King......I can just replace the ends if they are ever a problem again.  Still cheaper than buying new.
Any way its a start
AMC RULES
Looks beefy.   :handgestures-thumbsup:
Sparky
A front end alignment is one way to start off a resto project :ychain:   ..... Good luck!!
Mike............
Buda
Oh I dont know how well its aligned :teasing-neener:  but my left tie rod wont be falling off any more :handgestures-fingerscrossed:
953 nut
:text-coolphotos:  Even though they a short I am not too sure 3/8 is big enough to keep from bending. You may want to consider backing them up by slipping a piece of pipe that fits snugley over them
between the new rod ends. You can always give what you have a try and add the pipe later if it is needed.  :text-goodpost:
:USA:
Buda
953 I had the same thought that they may not be strong enough.......the pipe would take care of it for sure if they become a problem......the most weight I will have up front will be a blade for pushing snow :eusa-think:
KC9KAS
If you are pushing snow and hit something frozen with one of the front wheels, you will need to work on the tie rods again!
In this case, bigger (diameter) is better!
Howie
They may be a little small but my Raider 12 has been that way for 15 to 18 years. Have never bent them, although
if something hard was hit probably would
Buda
This is what I'm hoping for.....If I bend one......well they were easy enough to make and I'll go bigger next time.
Buda
A bit of progress.
Jake Kuhn
Looking good!
Buda
photo5.jpgThe fender painted the second time.....the first time I found a hair in it and just wet sanded the whole thing and resprayed.
Edited by Buda
Buda
Pullstart
that's the nicest bar stool I've seen in quite some time!
Buda
Buda
image1-2.jpegFitting the drive belt cover.  Now I realize I should have test fit this stuff before I painted.....Oh Well.....Fender had to be massaged to fit around everything and will need some paint repair. :banghead: or I will sand it again and respray....Live and learn
Buda
Clutch, brake linkage and lift handle all painted and installed.....progress
Buda
Starting on the engine.  A bit of carb cleaning and replacing of the needle and seat.
AMC RULES
:woohoo:   Some good looking  :wh: progress going on there.    :handgestures-thumbsup:
Wishin4a416
Looks real good! Thats one nice thing about redoing these, you can set it aside and go back to it anytime. Nice job.
Stigian
Nice work Sir, she's going to be beautiful when she's finished :handgestures-thumbup:
Buda
Thanks guys.......it's a slow process, time and money
Sent from my iPhone using Tapatalk
Buda
Molon_Labe
You've got a sweet looking machine there. Nice work!!
ben06351
Looks good. Nice work.
