Buda 11 #1 Posted June 16, 2013 Its gona be slow going as money it tight but here is my start Tie Rods Ran a die over 3/8 in cold rolled steel rod and got some tie rod ends at Farm King......I can just replace the ends if they are ever a problem again. Still cheaper than buying new. Any way its a start 1 Share this post Link to post Share on other sites
AMC RULES 37,143 #2 Posted June 16, 2013 Looks beefy. Share this post Link to post Share on other sites
Sparky-(Admin) 21,586 #3 Posted June 16, 2013 A front end alignment is one way to start off a resto project ..... Good luck!! Mike............ 1 Share this post Link to post Share on other sites
Buda 11 #4 Posted June 16, 2013 Oh I dont know how well its aligned but my left tie rod wont be falling off any more Share this post Link to post Share on other sites
953 nut 56,320 #5 Posted June 16, 2013 Even though they a short I am not too sure 3/8 is big enough to keep from bending. You may want to consider backing them up by slipping a piece of pipe that fits snugley over them between the new rod ends. You can always give what you have a try and add the pipe later if it is needed. Share this post Link to post Share on other sites
Buda 11 #6 Posted June 16, 2013 953 I had the same thought that they may not be strong enough.......the pipe would take care of it for sure if they become a problem......the most weight I will have up front will be a blade for pushing snow Share this post Link to post Share on other sites
KC9KAS 4,741 #7 Posted June 17, 2013 If you are pushing snow and hit something frozen with one of the front wheels, you will need to work on the tie rods again! In this case, bigger (diameter) is better! Share this post Link to post Share on other sites
Howie 899 #8 Posted June 18, 2013 They may be a little small but my Raider 12 has been that way for 15 to 18 years. Have never bent them, although if something hard was hit probably would 1 Share this post Link to post Share on other sites
Buda 11 #9 Posted June 18, 2013 They may be a little small but my Raider 12 has been that way for 15 to 18 years. Have never bent them, although if something hard was hit probably would This is what I'm hoping for.....If I bend one......well they were easy enough to make and I'll go bigger next time. Share this post Link to post Share on other sites
Buda 11 #10 Posted August 6, 2013 A bit of progress. Share this post Link to post Share on other sites
Jake Kuhn 1,556 #11 Posted August 6, 2013 Looking good! Share this post Link to post Share on other sites
Buda 11 #12 Posted August 25, 2013 (edited) The fender painted the second time.....the first time I found a hair in it and just wet sanded the whole thing and resprayed. Edited August 25, 2013 by Buda Share this post Link to post Share on other sites
Pullstart 63,265 #14 Posted August 26, 2013 that's the nicest bar stool I've seen in quite some time! The fender painted the second time.....the first time I found a hair in it and just wet sanded the whole thing and resprayed. Share this post Link to post Share on other sites
Buda 11 #16 Posted September 4, 2013 Fitting the drive belt cover. Now I realize I should have test fit this stuff before I painted.....Oh Well.....Fender had to be massaged to fit around everything and will need some paint repair. or I will sand it again and respray....Live and learn 1 Share this post Link to post Share on other sites
Buda 11 #17 Posted September 6, 2013 Clutch, brake linkage and lift handle all painted and installed.....progress 1 Share this post Link to post Share on other sites
Buda 11 #18 Posted November 9, 2013 Starting on the engine. A bit of carb cleaning and replacing of the needle and seat. Share this post Link to post Share on other sites
AMC RULES 37,143 #19 Posted November 9, 2013 Some good looking progress going on there. 1 Share this post Link to post Share on other sites
Wishin4a416 2,191 #20 Posted November 9, 2013 Looks real good! Thats one nice thing about redoing these, you can set it aside and go back to it anytime. Nice job. 1 Share this post Link to post Share on other sites
Stigian 1,234 #21 Posted November 10, 2013 Nice work Sir, she's going to be beautiful when she's finished 1 Share this post Link to post Share on other sites
Buda 11 #22 Posted November 10, 2013 Thanks guys.......it's a slow process, time and money Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Molon_Labe 731 #24 Posted August 21, 2014 You've got a sweet looking machine there. Nice work!! Share this post Link to post Share on other sites
ben06351 19 #25 Posted August 26, 2014 Looks good. Nice work. Share this post Link to post Share on other sites
