meadowfield
Super Bendy 4x4 wheel horse
HorseHead1089
meadowfield
Finished the light looms, here's the sidelights at dusk
And the spots
  • Like 4
KevinG
Looks great! Nice job!
meadowfield
Today's update, after being 12 nuts short of a full packet you can stop picking on me.
A quick zap in my magic tank
And voila, shiny nuts :D
Great weather up here today so time for some painting :)
Edited by meadowfield
  • Like 4
Jparkes43
Looks amazing as usual, can you tell me your secrets of your tank (please) i need to know it looks amazing. a pm would be taken nicely.
james
meadowfield
Been a while since the last update...A kind of naked front end picture whilst the engine was being rebuilt.
and a close up of the remote gear linkage for those who wondered how it worked
And the engine is now back in and running :)
callum12
I love this build, really interesting stuff.
the lights look great! just finished wiring LEDs on my WH too.
meadowfield
A long overdue update... bendy now has decals!
I finally made an exhaust :D, it was annoying the neighbours
Cue a piece of child's swing, a table leg and lots of holes
Filled with fibreglass and welded up
and a nice stainless heat guard
And finally.... Bendy now has a remote locking diff :)
Used a bike brake cable in order to span the articulation joints and make life a bit easier.
Spring loaded selector keeps it in or out of lock
And a quick video
http://youtu.be/Kw6FG_wYTqA
  • Like 4
  • Excellent 2
Catmanii
Fantastic build and really like the new muffler. Gives me ideas. :)
meadowfield
My son has been helping me this week whilst I've been at work :thumbs:
The exhaust heat shield is now done
0CBB54A1-0524-42EC-809D-5C2E6143FE0B_zps
The front hitch is well underway
7BE11F8B-8EDF-4608-86F8-ABBC5A73C842_zps
And the rear 3 point is painted and has check chains
09B4BB28-3F26-439F-B21B-B5F321B3DC0C_zps
Wired the front lights when I got home, not much to do now for Newby :)
meadowfield
this thread has been sparse on updates - having moved house and starting other projects...
It's time bendy had it's hydraulics finished, there's also a heap of other jobs to complete, including stopping the rear drive slipping when under water, rebuilding the magnum engine, adding a diff lock indicator, etc
For now, here is the D-series spool valve mounted with easy reach levers and linkages and decal to finish it off. I'm just starting on adding a power steering pump to the axle, driven from the clutch.
  • Like 4
HorseHead1089
I love the quality of a job you have put into super bendy, the finished product will be one fun machine!
callum12
wow didn't realise you were doing a front 3pt hitch! what will you use that for? dozer blade? power steering pump sounds like a great idea a few people have done that on youtube.
Callum:)
jcp0420
This is one hell of a build! Very unique.  Do you have any videos of it running and driving?
AMC RULES
From Marks Youtube channel...always an awesome watch.  :handgestures-thumbsup:
Edited by AMC RULES
meadowfield
Another two of my favourites
  • Like 5
Abe01
I have just sat here and read this entire thread. I have been a machinist for 17 years and have been lucky to work on some pretty cool stuff, it takes a lot to impress me engineering wise, and im certainly inpressed, my wife is not however as I kept shoving my phone in here face saying "wow check out what he did here" lol. I love how you used the u joint  to crate a knuckle. One question have you hung anything on your three point, and how did the steeing pump handle the weight?
meadowfield
Thanks, I realised I haven't done an update for a while.
the three point will lift 200lbs, or easily push down to lift the rear end...
Here's a few more pics of the power steering pump.
meadowfield
Been a while since the last update,  I was determined to lose the belts at the rear and use chains. Here's a few pics along the way, I've tried 3 or 4 different ideas, the final one  caused a bit of damage and forced me to abandon it. Despite adding large flanges to the sprockets, and tensioners, it all went wrong and jamm d up pretty bad!
Sarge
Might want to give these some thought -
http://www.ebay.com/itm/18MP012-6FA2-Imperial-Pitch-Pulley/182451940028?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D41670%26meid%3Dcd428539bc414e058a031b0e9160d274%26pid%3D100005%26rk%3D4%26rkt%3D4%26sd%3D182451930678
Figuring out the cog belt length is the biggest challenge but there are charts out there to match tooth pitch vs pulley diameter vs centerline....can't find it right now .
Sarge
953 nut
Did you consider using the drive system from a Harley Davidson? They are built for all weather conditions and lots of power.
Image result for harley davidson drive belt
Sarge
Exactly what I linked - many equipment manufacturers use that exact type of belt drive for high torque loads . If you want cheap access to those type of parts - go hunting in an auto wrecking yard and start pulling timing covers - many Japanese engines use that same belt design and many small idler pulleys and such - some even have stamped sheet metal flanges to help guide the belt and prevent contaminants from getting in the drive . Those belts can transfer more torque than most chains , won't stretch due to the Kevlar/Aramid fibers and can actually outlast a chain by quite a lot . I've watched a brother in law dump the clutch on a fully dressed Harley and snap that rear tire loose like nothing - which is a sight to behold...lol .
Sarge
tbarnhart
The problem with those cogged belts is exactly the same problem as steel roller chain-they won't twist. They will transmit a lot of torque, but the pulleys have to be held in exact rigid alignment. The problem Mark is dealing with is that the rear axle assembly on Bendy is the articulating section and the drive has to be able to run under load, but out of alignment. I'm not sure what to suggest, but I don't think a timing belt from an engine would stay on the pulleys at all.
meadowfield
well I went back to belts and Bendy has continued working well (as long as the belts aren't wet)
I've continued pulling old fence out that has been buried in the ground, and isn't good for mowing or kids.
it's pulling great :D
I lifted the front on sunday to have a look underneath and check all was ok...
and noticed this
one of my bearing carriers for the centre cardon joint had left the bearing out. I must've not noticed i needed a collar to hold the bearing in. Luckily there doesn't seem to be any damage done, so I've added a collar and reassembled.
meadowfield
Another long overdue update, it was always intended that a front three point hitch would be added...
So a bracket was made to fit under the engine between the chassis section.
and a cylinder that fits like so
the cylinder is too long so had to be chopped down to shorten the throw
It's tight in there, new 1/4 hoses are on order with 1/2" JIC connectors, might get to try it at the weekend.
and yes I lose even more approach angle :(  which bendy does suffer with, but I will be able to hand things off the front :)
  • Excellent 4
