jake22si 5 #1 Posted May 29, 2013 I picked up a kohler power pro 5000 runs great just no power output. I've tried flashing with a drill but no luck. Can't seem to find any parts info online. its model 5mm65 Share this post Link to post Share on other sites
Sparky-(Admin) 22,150 #2 Posted May 29, 2013 Did you take off the head end of the generator and look inside? Usually a couple screws and its off. My neighbor had one that was only putting out on one leg and it turned out that one of the push button fuses had expired but not in the tripped position. They make connections under there with wire-nuts at the factory which dont hold up to well to vibration. I would start by getting in there and giving everything a close inspection. Mike......... Share this post Link to post Share on other sites
Jeff-C175 7,203 #3 Posted May 29, 2013 Agree with Mike, 99% of troubleshooting is VISUAL. Most of the time you can SEE the problem! Share this post Link to post Share on other sites
jake22si 5 #4 Posted May 30, 2013 I took the panel off and had a look inside, tried to find some voltage with no luck. No wire nuts in this one, its all crimped and screwed. No power coming off the brushes either. Did read about a $350 voltage regulator that kinda has me scared. Share this post Link to post Share on other sites
leeave96 488 #5 Posted May 30, 2013 Sounds to me like you got a bad voltage regulator or tripped breaker. Share this post Link to post Share on other sites
Save Old Iron 1,568 #6 Posted June 4, 2013 some help may be available here http://www.smokstak.com/forum/showthread.php?t=77238 Share this post Link to post Share on other sites
