kylecurtis
c-100 8 speed
kylecurtis
I believe is a 68 c-100 the seat is all messed up I would like to know any parts i need to fix I don't know how to post pictures on here from my phone but a picture of a the metal on the frame snapped off there was only one bolt holding the fenders on
Sparky
Is there an ID tag on it with a model#? How about decals that say C-100? The C-100 was first introduced in 1974 and was built till 1977 when the model name changed to C-101. Before 1974 they were called a 10-8speed for 1973 only.
Mike.........
Don1977
If it is a 1968 It is either A Raider 9 if it's an 8 speed or Charger 9 if it is an auto. both came with 10 Hp Tecumseh. What is the model number on the side of the hood stand.
kylecurtis
The serial number is 58069
Model 1 0390 9
Don1977
It's a 1974 model. Pictures will help us tell what is wrong with it.
It should have the hinged fender with the tool box under it.
oldredrider
You probably have a broken frame brace. It's easily fixed with a wire welder.
Typical break on the C models.
  • Similar Content
    • davidfindlay
      By davidfindlay
      Looking to find a new home for my 84 (I think) C-145. It has a dump trailer with the enclosure for leaves, the PTO impeller to get the leafs into the trailer, the hoses for deck-to-impeller, impeller-to-trailer.
      I haven’t run it in over a year.
      The battery and the cable to the battery probably need to be replaced.
      Comes with a new head gasket still in the bag.
      Seat is cracked but still comfortable.
      Happy to answer questions or take other pictures.
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get an engine swap.
      Thanks,
      John
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
