COMMANDO6
Ignition Switch
COMMANDO6
I plan on getting back into the restoration of my Commando 6 now that the weather's warmer. I've got to strip and prime the frame and tranny, and then paint everything. Then I'll be looking into the little goodies to finish off the restoration like hubcaps, headlight assembly, etc.
I want to get a new 3 pronged ignition switch to go with the originality theme. I have been using a different one, and I'd like to get an original switch. I've looked around the internet, but the three pronged version is not exactly common. There are only 5 pronged ones on Ebay. My question is can I substitute a five pronged one in even though my H60 only needs and used a three pronged switch. Or if not, does someone here have one they'd be willing to sell?
Thanks in advance for the input.
armyvetwh
you may have to check quite a few shops, but i am pretty sure they may help you find the switch that is the right one. i can check all the parts i have, but need to see the setup where the prongs are and the lettering on the prongs :eusa-think:
