peter lena 8,635 #26 Posted August 5, 2020 tom2p, did you ever install that pulley on the rear of that deck? noticing the paint rub off area , is just about where you would install that pulley , a slight deflection , in that long unsupported routing , keeps things quiet . have that on all 5 of my decks . pete Share this post Link to post Share on other sites
tom2p 2,394 #27 Posted August 5, 2020 1 hour ago, peter lena said: tom2p, did you ever install that pulley on the rear of that deck? noticing the paint rub off area , is just about where you would install that pulley , a slight deflection , in that long unsupported routing , keeps things quiet . have that on all 5 of my decks . pete Pete - no - unfortunately have not gotten to that ... this year full of 'house projects' - with little time for 'tractor projects' on this subject - what type of pulley do you use and where did you purchase the pulley ? the belt defection at the time the picture was taken was especially bad because I had installed a lower quality new Toro 'OEM' belt ... I re-installed the old belt (true OEM belt) and it is better with less deflection ... still would be improved by an additional pulley though Share this post Link to post Share on other sites
peter lena 8,635 #28 Posted August 5, 2020 tom2p, did you ever install that pulley on the rear of that deck? noticing the paint rub off area , is just about where you would install that pulley , a slight deflection , in that long unsupported routing , keeps things quiet . have that on all 5 of my decks . pete tom, i would have to check the exact size to verify , but its in this groupe , https://www.ebay.com/i/311940791342?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=311940791342&targetid=930621147540&device=c&mktype=pla&googleloc=9003292&poi=&campaignid=10459991409&mkgroupid=100467641501&rlsatarget=pla-930621147540&abcId=2146000&merchantid=8024644&gclid=EAIaIQobChMI_NbfwIyF6wIVBIbICh0eRwBoEAQYBCABEgIcCfD_BwE. i always have a few on hand , pete Share this post Link to post Share on other sites
Sparky1984 29 #29 Posted September 1, 2020 Hey Guys, Maybe an alternate idea, on my 42" RD mower I used short lengths of chain threaded onto a SS 1/4" all thread and attached to the deck with screw eyes. Locking nuts/cotter pins on the ends keep it in place. Got the idea from my 72" Bush Hog RDTH. They've been on there about 15 years......no changes Share this post Link to post Share on other sites
peter lena 8,635 #30 Posted July 31, 2022 @tom2p tom , that idler pully is an easy addition , got mine on line , always have a spare , not a lot of push on the belt, just watched for most advantage spot , drilled a 3/8 " hole , used a thread free base bolt and washer , up from bottom of deck , size to size ,3/8 to match pulley bore , pulley will probably have a longer mount hole side , that goes down on deck top ,with washer to elevate bearing , use flat washer and elastic lock nut to secure . when I have my decks down / off , regularly look at total function / ease of spin , thats the to go after anything thats off , and get after it , its just what I do , have a good day , pete Share this post Link to post Share on other sites
peter lena 8,635 #31 Posted August 22, 2023 @Stepney just saw this , that unsupported belt buzz , is just that , that back side is easily 15" + without a flat idler pulley in the middle of that spread . just drilled a hole and added a little push in on the belt to fitting , used flat washers and elastic lock nut , 3" pulley , also regreased pulley , stop lubrication failure noise , all my decks have been done , no noise or wyning bearings , also did pto muel drive bearings , pto cone bearings . once , you have a quiet running deck , there is no going back , done 4 of them , pete Share this post Link to post Share on other sites
peter lena 8,635 #32 Posted August 22, 2023 @PeacemakerJack noticing all the exposed frame shots in your replys , did you try and steel fuel line on the inside angle of frame , holding spot ? eliminate , fuel hose break down , finish with 1 ft at each end with clear vinyl , for fuel filter , check valve . might do mine over winter , pete Share this post Link to post Share on other sites
peter lena 8,635 #33 Posted August 22, 2023 @tom2p ever try that idler pulley? that was just an add on whyle checking out rotational function , like your added grass trap , having horses more than 40 years , main thing I have found on them is functional , detailing , kind of like dragging a sled , on attatchments . that led me to correct , rough / sloppy spots . always looked at anything , to improve . that pto lever set up , was a constant , effort to use. not any more , used my C -85 as the test bed for experiments , once I got it smooth / easy / bombproof , basically did the same to the other 2 horses . made chronis issues a solid / reliable spot . electrical areas , wiring reroute , wire / cable wrap , add on rectifier grounding . lots of stuff . all 3 are solid , experiment a lot with ideas . just talking , pete Share this post Link to post Share on other sites
