Fordiesel69 259 #1 Posted May 9, 2013 In looking at my 875 model, I cannot see how a big block 10 HP would fit in that small space. But the book shows 875/1075 on the front cover. What was different to accomodate the big block. My 875 is a very awsome unit, but it is way underpowered. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,031 #2 Posted May 10, 2013 Same 6102 frame and 5465 hood Garry Share this post Link to post Share on other sites
sorekiwi 761 #3 Posted May 10, 2013 The few short frame tractors that used a 10 hp engine, used an engine with a special oil pan. Dont seem to be able to find a pic right now Share this post Link to post Share on other sites
Martin 2,131 #4 Posted May 10, 2013 (edited) the k241 is a small base engine with a low height oil pan to be able to fit the engine under the hood...... the small base engine doesnt have the 'ears' that the larger oil pan bolts to. a special short dipper connecting rod is needed as well. there are other differences too, but these are the main 'engine' ones........ normal wheel horse spec pan on a large base engine on the left and a low height pan next to it. i see the kiwi beat me to it while i was out in the garage with the camera..... Edited May 10, 2013 by Martin 1 Share this post Link to post Share on other sites
Fordiesel69 259 #5 Posted May 10, 2013 Thanks, looks super rare then..... Looks like a regular one won;t work. Oh well. I wonder if it is a special dipper, or if it can just be ground down a bit. Share this post Link to post Share on other sites
Martin 2,131 #6 Posted May 10, 2013 (edited) If you have a shallow pan and one of the c series isolator engines (or any small base kohler big block k for that matter) you could put one together. I have read on here that members have cut down the dipper to fit the shallow pan before. I don't think it would be too difficult to measure the length....... Just remember measure twice, cut once. Cut it too short and you will have no 'splash' I got the shallow pan to do one myself, just too many other projects on the go........ Sent from my iPhone using Tapatalk Edited May 10, 2013 by Martin Share this post Link to post Share on other sites
Retired Wrencher 5,440 #7 Posted May 10, 2013 forddesile69 this is the 1075 I had last year. I hope this helps you. if you any questions feel free to ask send me a message. Gary B...... Share this post Link to post Share on other sites
