Hodge71
401 engine issues
Hodge71
I'm hoping you guys might be able to help me out here. The Suburban 400 I got last year has been great since I got it. It was the only one of the lot of 4 that ran awesome. Well I used it to plow a couple of the smaller storms here over the winter and I wanted to mow yesterday. Well it wont start at all now. Fresh fuel, fresh plug and still very weak yellow/no spark. Where are the coils and points etc. on these little Kohlers? I know nothing about the little K series and could really use some help fixing her up tomorrow.
Thanks in advance for all suggestions
Edited by hodge71
buckrancher
coil and condenser are under the flywheel
points are under a cover on the side under the carburator
WH nut
Coil is uner the flywheel and point are on the left front of motor. If you got any snow up under the flywheel it could just be rusted up. Remove fly wheel to see, clean up with sand paper
  • Similar Content
    • bigbuck
      By bigbuck
      I had a fire in 2019 which destroyed my pole barns and some wheel horse tractors and parts. i'm looking for someone who can use the engine that went thru the fire. It is not pristine but there must be some usable parts
      please call George at 517-499-5678 for more info.
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • Keaton
      By Keaton
      i do not know how to route this throttle cable on this RJ 59, i will attach some pictures, i watched packrats video on adjusting the govner on his 401, it did not look the same. also i think that and is way to long so that might be part of it. ( and also the color on that block looks beautifull) there is come pics, the more the better!
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
