marvairplanes
Strange Noise ...Starter???
marvairplanes
1985 310-8 speed, Kohler K241S engine
When I turn the key and the starter engages, I get this VERY LOUD, squealing, piercing noise.  Loud enough that the neighbors 2 houses away can hear it.
Noise lasts only a second or two, while the engine is turning over.
 It obviously is coming from the starter.
Question: Does the starter require any type of lubrication/maintenance?
WH nut
Not really, but if its that bad the bushings are worn out. You may be able to save it but doubtful
dsholler
Don't know about the specific starter on yours, but the one on my M14 does seem to need to be lubricated. This has happened twice now when snowblowing, I guess all that stuff flying got some water inside the housing, and caused the gear to bind up on the shaft.  I used some graphite powder and it slid much better. So lubricating the shaft may be necessary. However, it sounds like yours is the shaft itself, and I do not think you can get at that very easily, without taking the whole starter apart, in which case you might as well either just fix it right, or replace it.
stevasaurus
Marv...check out this thread from a few years ago...if you have the "High Mount" starter...this is what you have... :)   Easy to tear into and fix what is not right.
953 nut
My 312-8 has been doing that same thing for six years, I have a new starter (been on the shelf for five years) to replace it when it bites the dust.
:USA:
tunahead72
:USA:
Likewise my '86 310-8, for at least that long.  I ended up selling the new starter that I bought to replace it after I read the thread that Steve linked below.  It's a good one, and I'll tear mine down at some point after I can't hear "the voices" over the screeches from the starter.
In the meantime, it's fun to watch the mice scatter outside my shed when I start it.  I'm thinking of bringing it down to our place in Virginia to try to scare the snakes out of the barn. :icecream:
marvairplanes
Bought a new starter (e-bay)...it arrived yesterday and it took all of 5 minutes to remove the 2 bolts and one electrical connection and install the new unit.
WOW !!!
Touch the starter key and it comes to life in a split second.
Marv
diamondred
Could it be that the gears are not fully engaged?
Edited by diamondred
rmaynard
Interesting subject. Had the same problem about 4 years ago, so I bought a new starter off eBay for a K-241. I knew it was going to be labeled "made in China", and when I got it, it was. But it was only $40.00 delivered. It has been working flawlessly since that time.
Fast forward to two years later. My neighbor wanted a new starter for his meticulously restored C-141. I told him about the $40.00 deal on eBay, but he said he wanted to get a genuine Kohler brand. He did, and it cost him close to $250.00. And what did it say on the side of his genuine Kohler box?
Product of China.
I think there is a moral to this story, but for the life of me I don't know what it is.  :scratchead:
km3h
Unless the starter is a total wreck, I always rebuild them. New paint, new brushes and new bushings and they are good as new and cost practically nothing in comparison to a new one.
