Kevbo 80 #1 Posted May 3, 2013 Free is always nice! Engine starts right up which was a plus! Don't really know what to do with this as it doesn't have a deck. It's such a simple design! Should I restore it? Wouldn't really be worth it but it could be fun...hmmm....do these trannys have a drain plug?? Maybe ill keep it for my kids to play with someday (when I have kids). I need ideas guys! What should I do with this? Is it worth anything? Share this post Link to post Share on other sites
bowtieguy 334 #2 Posted May 3, 2013 Maybe a boat anchor??? Share this post Link to post Share on other sites
Jake Kuhn 1,579 #3 Posted May 3, 2013 Free is always very nice, and it looks to be in pretty good shape! As for a value its not worth a ton, probably about 100 bucks without the deck, but it might be a fun one to just drive around. Jake Share this post Link to post Share on other sites
Wheel-N-It 2,971 #4 Posted May 3, 2013 Ii think you should give it some long overdue maintenance, clean it up, and put a better (free or cheap used) seat on it. Then just call it good. Maybe later you can find a good used deck for it. Don't spend a bunch of money on it though Kevin, its not one that has childhood memories. 1 Share this post Link to post Share on other sites
SousaKerry 502 #5 Posted May 3, 2013 No drain plug as the old peerless transaxles use a grease called Bentonite, Really nasty stuff and impossible to find as it is no longer manufactured. I have actually salvaged the grease out of junk transaxles to get more when working on them. Those tractors can make good cheap go-carts for the kids but that's about it. Not really built heavy enough to do anything but mow flat level ground. Some people will play with the pullies to speed them up a bit. Share this post Link to post Share on other sites
bmuone 15 #6 Posted May 3, 2013 I decided a long time ago that when I had grand kids I did not want them riding on four wheelers or dirt bikes at my house. So I came across a 211-4. Brought it home....took it completely apart....primed...painted...and put back together again. Left the deck off so it is a ride on and they love it. Then I found another 211-4 and I am going to do the same to it. (except it will need another motor). My advice is to fixer up and save it. Someday you'll be glad you did. They may be little tractors, but the kids learn to respect the fun and the dangers of driving on a slower more steady vehicle. And you will greatly enjoy restoring it ! Dayton 1 Share this post Link to post Share on other sites
70sVintageTrikes 19 #7 Posted May 5, 2013 No drain plug as the old peerless transaxles use a grease called Bentonite, Really nasty stuff and impossible to find as it is no longer manufactured. I have actually salvaged the grease out of junk transaxles to get more when working on them. Those tractors can make good cheap go-carts for the kids but that's about it. Not really built heavy enough to do anything but mow flat level ground. Some people will play with the pullies to speed them up a bit. If you cant find the bentonite grease, then google must not work for you.. haha It is still being made. Share this post Link to post Share on other sites
