welderman85
oil job to slow rust
welderman85
i picked up a 753 a while ago. the hood has a lot of surface rust on it. i was wondering if spraying it with some sort of oil would slow the rust. what oil or spray should i use. thank you very much
wallfish
Stevebo would know best, he's tried everything
stevebo
Go here
VinsRJ
If you ever plan on repainting the hood, I would say not to do it. If you are looking to keep the weathered look then it seems to work.
WH Raider10
Hi,
Wipe some boiled linseed oil on there! You'll be amazed.  :)
P-J
