Glenn Killebrew
312-8 idler pulley cover spacer
Glenn Killebrew
I have a 1986 Wheel Horse lawn tractor series 312-8 model 21-12k803. The spacer that is behind the nut is missing on the front idler pulley cover.These pulleys have the mower deck belts ride on them. Any idea where i can find this? I do not have a parts diagram to ID this part. There may also be a flat washer missing as well. Thanks.
WH854
you need  your model# for your mower to get those P/Ns you can use (05-42MS05) look at the mule drive section :thumbs: Here
https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro
Chas
wallfish
You can pick up a 3/4" ID bronze bushing at any decent hardware store. I don't know the exact length of that spacer but the bushings are easy to cut if you can't find the exact size.
chazm
Hi Glen - part number for the nut is # 915007 or # 111841 . their saying its a 3/4-16 nut. May be able to get one from Mcmaster/carr
Good luck :handgestures-thumbupright:
Chasm :flags-waveusa:
WH854
P/N for the outer spacer is(101757) inside between pulleys is (101734) that nut is an Eslok nut 3/4-16 P/N 915007
Chas
Glenn Killebrew
Thanks everyone. Redsquare members rock especially WH 854. I never could find a diagram of the spacer in any diagrams. I found the spacer under the  diagram on the kingline.com website under idler assembly. Jacksmallengines also has it. I guess Ijust overlooked the lower part of the mower deck diagram. Part number on diagram
13 101757 SPACER-OUTER $2.71
gwest_ca
From my notes
Outer spacer between cover and pulley # 101757 is 1/2" long
Inner spacer between pulleys # 101734 is 5/8" long
Garry
  • Similar Content
    • swedish_wheelhorseclub
      By swedish_wheelhorseclub
      my wheel horse c-160 aoutomatick
      folow me on Instagram
      @swedish_wheelhorseclub
    • DennisThornton
      By DennisThornton
      I thought for a bit for a good title and still don't know how best to phase it...  Second best Wheel Horse forum?   ??
      A couple years ago I scoured the Internet for Wheel Horse info and while I certainly found other forums and I certainly gathered Wheel Horse info elsewhere I settled down here and I'd say 99 percent of the time I stay here. Comfortable, great info, great guys, lots of pictures and I truly believe that this is Wheel Horse Central!  But I was wondering, do any of you cheat?  A little?  Do you wonder off at night and return in the early morning hours to visit other sites?  Sometimes just to look around?  I KNOW some of you do!
    • zanepetty
      By zanepetty
      Does anyone have any good pictures of where the throttle and choke cable goes on my 753? I'm thinking one runs over the head and the other goes under the engine shround but I can't remember for sure. Any pics or help is appreciated. Also does the little hooked spring on the govenor arm go through the notch on this disc? Thanks in advance.
    • Sybesma07
      By Sybesma07
      What would a wheel horse trailer like this sale for and are they hard to find?
    • Motor Head110
      By Motor Head110
      I went to start my 856 this morning to plow snow and I noticed the rear end was locked up (again). I took the shifter out and looked in the hole. There was no rust. And the I took a large screwdriver and tried to move the forks. They moved. Im all out of ideas. does anyone know what could be wrong with it?
