Wishin4a416 2,191 #1 Posted April 13, 2013 What is the easiest way to remove the brake and drive shaft seals. I see the axle seals are plastic and there is more room there to pick them out but the other 2 are tight on space and metal. And does the shift handle need to be removed to split the case? Thanks Share this post Link to post Share on other sites
rmaynard 15,610 #2 Posted April 13, 2013 I remove those seal the same way as I remove the axle seals, with a dental pick. The shifter handle should be removed first just for ease of work. It's done easily by backing out the set screw, so why leave it in? Share this post Link to post Share on other sites
Wishin4a416 2,191 #3 Posted April 13, 2013 I remove those seal the same way as I remove the axle seals, with a dental pick. The shifter handle should be removed first just for ease of work. It's done easily by backing out the set screw, so why leave it in? Thanks Bob. The reason for the shifter question is the bolt is broke and I dont have a drill bit that will even touch it. I wanted to drill it and then use the easy out to remove but no luck there. Share this post Link to post Share on other sites
stevasaurus 22,869 #4 Posted April 13, 2013 You have to remove the shifter to separate the tranny. The shifter is mounted in the right half and the forks are mounted in the left. Share this post Link to post Share on other sites
