B-8074 19 #1 Posted April 8, 2013 Has anyone found replacement tie rod ends other than from Toro? I was thinking maybe from a compact car. Share this post Link to post Share on other sites
SCOOBY 312-h 14 #2 Posted April 8, 2013 i have seen heim joints they are spheireical joints and they last a lot longer than the regular joints. our local ace hardware sells them you may find them at lowes or home depot. Share this post Link to post Share on other sites
GlenPettit 1,717 #3 Posted April 8, 2013 There's several on eBay right now, (two different people make them; New Jersey & in Indiana), about $45/pair -- several different brands of small tractors use the exact same tie rods/ball joints, very nice and heavy duty, they work perfect on my Wheel Horses. Plus there lots of both new and used ones for sale at the big Wheel Horse Show in PA, June 21 & 22, and the prices are very good (less). Share this post Link to post Share on other sites
ToroHorse 5 #4 Posted April 8, 2013 McMaster Carr has a number of sizes, materials & sealed units. The first link are identical to the original used on many tractors with an added seal on the ball joint. Others are greasable, stainless steel etc etc: http://www.mcmaster.com/#end-links/=m8dgns http://www.mcmaster.com/#end-links/=m8dh2h 1 Share this post Link to post Share on other sites
JUSS10 250 #5 Posted April 8, 2013 i use the economy rod ends from racingrodends.com. They are around $3 a piece and they do free shipping. I get two left hand and two right hand rod ends, picked up some LH and RH 3/8-24 taps and found a steel tube that i could thread the inside to 3/8. Makes for prettty affordable, adjustable, tie rods. Share this post Link to post Share on other sites
squonk 42,534 #6 Posted April 8, 2013 I made these tie rods with sperhical rod ends, some round stock and some bolts. Share this post Link to post Share on other sites
KC9KAS 4,744 #7 Posted April 8, 2013 Copied from another post on RS Make your own out of steel rod and a couple of threaded ball joints. Get smooth rod and cut threads at the ends, and then you can get these nice heim style joints from McMaster Carr, they really do a nice job. (You could also use standard universal ball joint ends, but at the same price, why?) I haven't made any for a WH yet, but I use them on my Cub 100, and they work well. 2 Share this post Link to post Share on other sites
Duff 206 #8 Posted April 8, 2013 All parts from McMaster-Carr, and not that expensive! ~Duff 2 Share this post Link to post Share on other sites
B-8074 19 #9 Posted April 8, 2013 Thanks for all the replies. There's a lot of good info here, but I was looking for greasable ones for use with a forward swept axle. Share this post Link to post Share on other sites
dodge78 94 #10 Posted April 12, 2013 try # 4444t812 and some boots http://www.midwestcontrol.com/series.php?id=190 1 Share this post Link to post Share on other sites
big mike 13 #11 Posted April 12, 2013 I get mine from Motion Ind. ,less than 10.00 each. 1 Share this post Link to post Share on other sites
Don1977 604 #12 Posted April 12, 2013 I used 1/2 Heim joints and bushed them down to 3/8" and used 3/8" NF bolts. 1 Share this post Link to post Share on other sites
