Save Old Iron
C Series Safety Switch Substitutes
Save Old Iron
If you need replacement safety switches for the clutch pedal or PTO lever on a C Series, replacements are available at the small engine parts supplier for $40+ each
or
auto parts stores may have what you need on the shelf. Ask for a Backup Reverse Light Switch for a 1979 Jeep CJ5.
Cost can be as low as $15 each.
I just picked up 2 new ones off eBay for $9 each.
Just remember to keep the mounting nut off the old switch. The new switches do not appear to come with the nut.
c/o Excelsior Auto Parts - Davenport, Iowa
SousaKerry
Nice!!   I will have to check into that
rmaynard
You can also do a search for Stens 430-193, which is a direct replacement for the Wheel Horse safety switch. I have seen them for as little as $18.20, and they have the correct slide-on terminals on the back to fit the existing wiring connector.
JimD
Both examples appear to have the correct slide on terminals. It's nice to know they are still available. :)
Trouty56
Not as good as SOI's $9 deal but........
Autozone part DR429 about 18 bucks
NAPA part 7-01971 about 19 bucks (less with preferred discount)
Edited by Trouty56
Lane Ranger
More good information for replacement parts from the Red Square members.
IndyWH (Marshall Fyffe) and I were discussing this parts issue about Wheel Horse yesterday.   The amount of parts that are still available from suppliers for items Wheel Horse/Toro used or use to supply is still significant.   Often however you have to do a reverse engineering research project to find the new part supplier.
One of the reasons I come to Red Square about every day is that the members tell other members how we can get parts to keep our tractors going!
Thanks Chuck, Jim and the two Bob's for posting these items!
rmaynard
...Often however you have to do a reverse engineering research project to find the new part supplier.
Lane,
I am currently doing one of those "reverse engineering projects" on several Kohler engine parts right now. Although these parts are still available from Kohler, they are ridiculously priced. Hope to reduce our cost on them by at least 50%.  More later...
Edited by rmaynard
TDF5G
The Jeep backup light switch is not a correct replacement.  I just bought one.  It's a Crown brand part no. J5751207.  It's in a normally closed position.  The interlock switches on B-C series are normally open.   In other words, the Jeep switch operates opposite of the :wh: switch.
Edited by TDF5G
CasualObserver
Chuck? @Save Old Iron
doc724
These switches are indeed normally open.  (when you step on the clutch you close them completing the circuit).  They are made by Cole Hersee, a division of Stoneridge/Jospeh Pollak Company.  Do a search for Pollakaftermarket.com.  They do have distributors
TDF5G
I did this.  They don't have the button terminal open switches listed.  They are stud terminal.  I've ordered a Stens 430-193/Gravely 020916.
TDF5G
I received the Stens 430-193 switch yesterday and it is correct for the B,C series, normally open, interlock switches.  Has correct button terminals.
