23 Reo 229 #1 Posted March 25, 2013 Does anyone know where I can get control arms/ball joint assemblies for my 72 Raider 14 part numbers RH 102592 and LH 102593 ? Thank you Share this post Link to post Share on other sites
Shuboxlover 478 #2 Posted March 25, 2013 How long are they center-center? 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,031 #3 Posted March 25, 2013 78-2900-01 (replaces 102592 and 102593) TIE ROD ASM still available from Toro 3 adjustable pieces now replace the original one piece Garry 1 Share this post Link to post Share on other sites
Tankman 3,518 #4 Posted March 26, 2013 You might try partstree.com; http://www.partstree.com/parts/?pn=78-2900-01 Lowes and Home "Cheapo" have tie rod ends. I don't know if they're the right size. I might take a peek-a-boo at a pair. You would then need to cut a rod and thread both ends. http://www.appliancerepair.homedepot.com/PartDetail/Ball-Joint-Assembly/9230448A/1606406 1 Share this post Link to post Share on other sites
Buckshot 1 15 #5 Posted March 26, 2013 I buy from Mcmaster-Carr. good selection and a heck of lot cheaper them those bos stores. 1 Share this post Link to post Share on other sites
JUSS10 250 #6 Posted March 26, 2013 I make my tie rods. i get rod ends from racingrodends.com then use steel tubing that i tap with a left and right hand 3/8" fine thread tap. That said, i know not everyone has the ability to do this but it is much cheaper and they look nice too! Justin 1 Share this post Link to post Share on other sites
Don1977 604 #7 Posted March 26, 2013 I used 1/2" heim joints with bushings to 3/8" at the spindles. Made that change around 1988 the tie rods were falling off about ever other time I mowed. Got tired of beating them back together to finish the yard. 1 Share this post Link to post Share on other sites
roscoemi 245 #8 Posted March 26, 2013 I bought joints and rods from McMastercarr for about $50 shipped and made my own, and they are greasable. 1 Share this post Link to post Share on other sites
Duff 206 #9 Posted March 27, 2013 (edited) Same here - I made these with parts from McMaster-Carr. Not difficult! Duff Edited March 27, 2013 by Duff 2 Share this post Link to post Share on other sites
