23 Reo
Control arms/ Ball joint assembly
23 Reo
Does anyone know where I can get control arms/ball joint assemblies for my 72 Raider 14
part numbers RH 102592 and LH 102593 ?  Thank you
Shuboxlover
How long are they center-center?
gwest_ca
78-2900-01 (replaces 102592 and 102593) TIE ROD ASM still available from Toro
3 adjustable pieces now replace the original one piece
Garry
Tankman
You might try partstree.com;
http://www.partstree.com/parts/?pn=78-2900-01
Lowes and Home "Cheapo" have tie rod ends. I don't know if they're the right size.
I might take a peek-a-boo at a pair. You would then need to cut a rod and thread both ends.
http://www.appliancerepair.homedepot.com/PartDetail/Ball-Joint-Assembly/9230448A/1606406
Buckshot 1
:) I buy from Mcmaster-Carr. good selection and a heck of lot cheaper them those bos stores. :flags-waveusa:
JUSS10
I make my tie rods. i get rod ends from racingrodends.com then use steel tubing that i tap with a left and right hand 3/8" fine thread tap. That said, i know not everyone has the ability to do this but it is much cheaper and they look nice too!
Justin
Don1977
I used 1/2" heim joints with bushings to 3/8" at the spindles. Made that change around 1988 the tie rods were falling off about ever other time I mowed. Got tired of beating them back together to finish the yard.
roscoemi
I bought joints and rods from McMastercarr for about $50 shipped and made my own, and they are greasable.
Duff
Same here - I made these with parts from McMaster-Carr. Not difficult!
Duff             :thumbs:
Edited by Duff
