Thehunter 9 #126 Posted September 24, 2013 got the main side panel painted and the decal installed. the idler (tensioning) pulley makes contact with the cover panel. It seems there's not even enough room there for the bolt head. Am I doing something wrong here? Share this post Link to post Share on other sites
Thehunter 9 #127 Posted September 26, 2013 my buddy turned down the exhaust pipes in the lathe to get rid of the "bark". thanks mark! the bolt head for the idler pulley was rubbing on the belt guard, so mark turned down the bolt in the lathe as well ahhhh much better Share this post Link to post Share on other sites
Thehunter 9 #128 Posted September 26, 2013 got all the wiring done, everything was heat shrinked got the throttle and choke cables hooked up and how she sits now... 1 Share this post Link to post Share on other sites
Jake Kuhn 1,554 #129 Posted September 27, 2013 Very nice...are those stainless fittings? Share this post Link to post Share on other sites
Thehunter 9 #130 Posted October 4, 2013 started on the hood, this is going to take a long time to get right. my buddy tig'd the holes closed (there were 4 or 5 where a PO mounted lights and about 5 on the bottom of the hood for some unknown reason). ground flush, pits will be refilled and ground again needed to cut out this abomination and she's out bottom section of the hood... first round of welding and grinding. my goal is to not use body filler anywhere on the tractor, including the hood Share this post Link to post Share on other sites
gumshoes 200 #131 Posted October 4, 2013 Why don't you just buy a better hood Why don't you just buy a better hood Share this post Link to post Share on other sites
Thehunter 9 #132 Posted October 4, 2013 the satisfaction of preserving the original, along with the learning experience gained thru the restoration outweighs the benefits of buying a nicer one (if I could even find one) 1 Share this post Link to post Share on other sites
bowtiebutler956 650 #133 Posted October 6, 2013 You do nice work! Matt Share this post Link to post Share on other sites
Thehunter 9 #134 Posted October 8, 2013 my buddy turned out another part for me, a delrin steering cap. needed something to break up the red of the wheel. added hardware to fill the holes left behind for the steering arm mount and greased the steering gears w/ mobil 1 synthetic grease Very nice...are those stainless fittings? Hi Jake, yes they are stainless Share this post Link to post Share on other sites
