Jack Fate 7 #101 Posted August 6, 2013 i took the day off today to run some much needed errands, and decided to build an e-tank at lunch. I think it came out pretty good. The first culprit was one of the footrests. here's the tank... starting to "cook" here she is before the dip... i'll post pics when it's done, hope it comes out good. So been looking on how to build an E-Tank , found only e ciggerett tank I'll bet someone here knows Share this post Link to post Share on other sites
KATO 115 #102 Posted August 6, 2013 Type electrolysis-tank in google ...you will get lots of info :handgestures-thumbupright: Share this post Link to post Share on other sites
Jack Fate 7 #103 Posted August 7, 2013 Thanks just what I needed " electrolisis" was the key word here Cheers Share this post Link to post Share on other sites
Thehunter 9 #104 Posted August 7, 2013 here's how I secured the wheel to the hub to the dual wheel adapter... added stainless fill plug does anyone have a spare brake link (p/n 3979). I am in desperate need!!! let me know the price if you have one you can part with please. Share this post Link to post Share on other sites
Thehunter 9 #105 Posted August 7, 2013 I got the brake band painted and I installed a new friction liner of the same dimensions. I used 2 ton epoxy and clamped it all together overnight. Once the epoxy squeezed out the sides I immediately wiped it off using white vinegar. that is the only stuff I've found that dissolves two part epoxy Share this post Link to post Share on other sites
kaiser 100 #106 Posted August 7, 2013 really nice work. i can't wait to restore one of my own. just need to finish a car first. this thread rocks! Share this post Link to post Share on other sites
Thehunter 9 #107 Posted August 8, 2013 brake band material bonded very nice installed Share this post Link to post Share on other sites
Thehunter 9 #108 Posted August 8, 2013 rebuilt the carb last night with new needle seat, float needle and gaskets. cleaned all the needle ports polished the carb body with a wire wheel, also took the fuel pump off and did that as well all installed. I think i'm going to restrip the air filter and breather cover and paint them blue as well to match Share this post Link to post Share on other sites
Thehunter 9 #109 Posted August 12, 2013 hi all, got the hood stand filler panel and bracket welded, thanks Mike. welds ground and first coat of primer I sandblasted (again) the air filter cover to match the engine, the red didn't look right. installed new air filter and prefilter. Share this post Link to post Share on other sites
Thehunter 9 #110 Posted August 14, 2013 my buddy fabricated a custom length tie rod, thanks Mark, came out perfect! my ocd kicked in and I had to make a new button for the point pusher. I couldn't have that old plastic orange one in there. old vs. new button installed tie rod installed Share this post Link to post Share on other sites
Thehunter 9 #111 Posted August 14, 2013 the thumb screws had to be turned down in the lathe, they were too long and were hitting the steering gear at the end of the stroke. thanks again Mark. put the grass screen on just to see how it looked painted to match the wheels, I like it and here's where I'm at now Share this post Link to post Share on other sites
Thehunter 9 #112 Posted August 16, 2013 got the rear brake linkage all setup new starter generator, was an inch longer than stock, needed to use a 1" spacer points set to .020 @ open, and cover installed with bushing Share this post Link to post Share on other sites
Thehunter 9 #113 Posted August 19, 2013 got the fenders and tank painted, and the dash decal painted to match the wheels, decal installed closeup of the tank, very happy w/ how the paint wet out used a scotchbrite pad chucked up in a drill to apply a brushed finish on the gas cap I was trying to adjust the throttle linkage spring when it snapped... directly into my hand. I think this is the 4th time this tractor has drawn blood. Share this post Link to post Share on other sites
Pullstart 63,198 #114 Posted August 19, 2013 Hey - WH red! Sorry to hear about the mishaps along the way... Nice progress! Share this post Link to post Share on other sites
Thehunter 9 #115 Posted August 24, 2013 torqued the head bolts to spec, torqued the flywheel nut, installed flywheel cover and installed new decals Share this post Link to post Share on other sites
Jake Kuhn 1,556 #116 Posted August 24, 2013 Looking good! I really like that grass screen! Share this post Link to post Share on other sites
horsesaver98 18 #117 Posted August 25, 2013 that is looking real good Share this post Link to post Share on other sites
Thehunter 9 #118 Posted September 9, 2013 hi all, made a lot of progress this week. I bought another tool box on ebay that was in perfect shape. got that painted and mounted, along with the dash tower and fenders. I installed the shift pattern decal, and mounted the gas tank finally. Next I have to do the wiring and sort out the exhaust mounting. And cut the steering shaft to the proper height. Share this post Link to post Share on other sites
welderman85 53 #119 Posted September 10, 2013 Great work I really like the dual rear wheels Share this post Link to post Share on other sites
Thehunter 9 #120 Posted September 16, 2013 got the starter generator bracket installed got the steering wheel painted and installed installed the fuel bowl under the tank Share this post Link to post Share on other sites
mtm100 0 #121 Posted September 16, 2013 Where's the bushing for the steering shaft? Bet someone is going to be making one soon Share this post Link to post Share on other sites
jbumgarner 12 #122 Posted September 16, 2013 Looks good, I really wish I had friends like yours that were local. Great job, cant wait to see it finished. Share this post Link to post Share on other sites
Thehunter 9 #123 Posted September 18, 2013 got the fuel line in side panel primed (I added a return tab on the bottom to prevent the belt from rubbing on a raw edge). just making sure everything fits ok here... wanted to see what the disk harrow looked like hooked up Share this post Link to post Share on other sites
Thehunter 9 #124 Posted September 23, 2013 cleaned and mounted the amp gauge painted the voltage regulator cover and got it mounted to the starter generator Share this post Link to post Share on other sites
jaebo74 7 #125 Posted September 24, 2013 I really enjoy the blue engine, it breaks the monotony of everything solid red. (not that i don't just love red) Share this post Link to post Share on other sites
