Jake Kuhn 1,554 #26 Posted March 27, 2013 The wheels look great! Share this post Link to post Share on other sites
Thehunter 9 #27 Posted March 28, 2013 so i decided to cut out the entire transaxle mount and fabricate a 5/16" steel plate to fill the void. here's a shot of the quick mock up in progress... I drew up the plate in CAD... also, the UPS man came bearing gifts, 2 new tri-ribs for the front... Share this post Link to post Share on other sites
raider10-8 9 #28 Posted March 28, 2013 where did u get those tri ribs and how much. i really want to put those on my tractor Share this post Link to post Share on other sites
Thehunter 9 #29 Posted March 29, 2013 Radider10-8, i got them at GCT Wholesale, 39.50 for 2 tires (part number and website below) http://www.greaterclevelandtire.com/servlet/StoreFront 4.00-8 4P Deestone F-2 Tri Rib D401 (2 tires) $39.50 USD1$39.50 USD Share this post Link to post Share on other sites
Thehunter 9 #30 Posted March 29, 2013 My friend fabbed up a replacement battery bracket from my CAD file. I checked the fit using the old battery, and i need another 1/8" in the width, it's a little too tight. I was hoping to tack this in place this weekend, but i'll have to wait. Share this post Link to post Share on other sites
Jake Kuhn 1,554 #31 Posted March 29, 2013 Look up on eBay for tri ribs. I get them on there for $55 with tubes. Think the sellers name was k morrow or something? Share this post Link to post Share on other sites
Thehunter 9 #32 Posted April 1, 2013 Hi guys, did some good work on the horse this saturday. My buddy fabbed another battery bracket 1/8" wider, and this one fit like a glove! Share this post Link to post Share on other sites
Thehunter 9 #33 Posted April 1, 2013 now it was on to the transaxle mount. I used 5/16" steel, about twice as thick as stock... 1. first I bolted the new plate to the original to justify the location of the mounting holes second, i scribed lines to mark the location for my 2 cuts next, I clamped a piece of bar stock along one of the lines to act as a guide while cutting with the angle grinder Then i cut out the center section Here's how it will look when tacked... old plate next to the new one, this should be pretty beefy! Share this post Link to post Share on other sites
Thehunter 9 #34 Posted April 1, 2013 on saturday i went over my friend's house and he welded the plate and battery bracket (he did an awesome job)! here's the plate being tacked here it is all welded up action shot... welds ground flush (can't even see a trace finally got the frame shot with primer! Share this post Link to post Share on other sites
gumshoes 200 #35 Posted April 1, 2013 Good job Dave Share this post Link to post Share on other sites
Thehunter 9 #36 Posted April 2, 2013 got the clutch pedal, foot rests, frame, front axle, and battery tab in primer on saturday, couldn't help fitting them together last night for a photo Share this post Link to post Share on other sites
Thehunter 9 #38 Posted April 4, 2013 decided to split the tranny last night to see how it looked. when i drained the oil it was a little milky so there must have been some water that passed thru the boot. i've never split a tranny before, so i'll try to document what I do in case anyone is curious. all the gears looked good which i was happy about. where the 2 balls/spring/pin go, there seems to be a plug of some sort in the case. does that punch out because it seems you'll need access to that passage... Share this post Link to post Share on other sites
Thehunter 9 #39 Posted April 5, 2013 hi all, i got the transmission gears pulled last night, now i have 2 nice halves... one is soaking in the e-tank as we speak. shown below is the order in which i removed the gears... also dropped off the k161 block at the machine shop on the way into work this morning. it's getting bored and having head work done. Share this post Link to post Share on other sites
c161rat 185 #40 Posted April 5, 2013 Nice work so far!!!!! and welcome to Red Square!!!!!! Share this post Link to post Share on other sites
Thehunter 9 #41 Posted April 8, 2013 finally got some red on her! Share this post Link to post Share on other sites
Jake Kuhn 1,554 #42 Posted April 8, 2013 Looks great! Share this post Link to post Share on other sites
fabricator2009 48 #43 Posted April 8, 2013 NIce job so far. Share this post Link to post Share on other sites
Ken B 3,164 #44 Posted April 9, 2013 Lookin real nice. What kind of paint did you choose to use? Share this post Link to post Share on other sites
gumshoes 200 #45 Posted April 9, 2013 Your Brave . Good job rookie. You are now a veteran. Share this post Link to post Share on other sites
Thehunter 9 #46 Posted April 9, 2013 Lookin real nice. What kind of paint did you choose to use? Hi Ken, I used Rustoleum Regal Red, Rustoleum rusty metal primer on the cast parts, and Rustoleum high build primer on the frame. After priming I used soapy water followed by alcohol followed by a tack cloth prior to shooting the color. Your Brave . Good job rookie. You are now a veteran. haha, thanks Dave! Share this post Link to post Share on other sites
Thehunter 9 #47 Posted April 9, 2013 last night i finally started to reassemble. I added 2 foam adhesive backed strips to the battery tray... I also assembled the front axle (greased pivot w/ Mobil 1 synthetic grease), clutch (greased this pivot as well), footrest, and new battery. I decided to use all SS hardware. sorry for the bad iphone pics... Share this post Link to post Share on other sites
Thehunter 9 #48 Posted April 9, 2013 anyone know the thread pitch for the front axle grease zerks? i'm thinking they're 1/4-28... Share this post Link to post Share on other sites
JimmyJam 542 #49 Posted April 9, 2013 Wow, you are really moving along on the restoration! Great job! to Red Square! I am not far from you, in Taunton, BTW Dave (gumshoes) is truly a great guy, a true friend and a wealth of knowledge! We should get together some time!! Share this post Link to post Share on other sites
chevyaddict83 39 #50 Posted April 9, 2013 Wow, you are really moving along on the restoration! Great job! to Red Square! I am not far from you, in Taunton, BTW Dave (gumshoes) is truly a great guy, a true friend and a wealth of knowledge! We should get together some time!! I'm thinking we all need a dunks meet-up soon too! Sent from my 416-8 1 Share this post Link to post Share on other sites
