Countdown To Christmas!
whc160
MY NEW HUB PULLER
whc160
Well I have been replacing alot of axle seals.  Have been lucky using a 3-jaw puller and have not broken a hub.  I figured my luck might run out one of these days.  So I thought it was time to make a puller.  Went to the local machine shop to get the stuff I needed.  Well I ended you just having them make it for me.  For the price and me not really having the time.  Here is some pics of it.
Got to use it yesterday and it worked great.  I don't know why I waited so long to get this done.  Here are some more pics.
  • Like 4
AMC RULES
Looks beefy...what did they charge you?  :handgestures-thumbsup:
whc160
They charged me $75 for everything.  I didn't think that was to bad.
groundhog47
:woohoo: VERY effective looking puller, can we call it "Hub Saver"  :), don't know whether you or fabricator came up with idea but :text-bravo:
rmaynard
How are you holding the axle from turning?
fourwheels0
it looks like you could just put a pipe wrench on the tube to keep it from turning.
that's a great looking setup and idea.
octfst
thats a great idea I love it
Wishin4a416
Looks like a dandy!!! Do you use the impact wrench with it?
whc160
Yes the idea was mine.  I took them an old hub and a drawing I had made to them.
Also I do use a 1/2" drive impact wrench.  With the impact you really only need your hand to hold it from turning.  But if you did not have an impact you could put a wrench on the nut that is welded on at the top for the all thread.  Then use a ratchet to turn the all thread in.
squonk
Here's my puller. It was a special tool for GM when the x body  front wheel drives came out. We never used them The wheel bearings about fell out when you removed the bolts. Picked it up for a buck when the dealership moved into a new bldg and they were cleaning out. Fits the WH hubs perfect and run the impact on it. :)
Edited by squonk
