perry 82 #1 Posted August 5, 2008 to go along with mike's bead breaker idea. got this tip awhile back from my buddy who works at a trucking company. where he has to mount some off the tires buy hand. when trying to dis-mount or mount tires from the rim. use black magic tire wet . spray some around the bead to aid in breaking away from rim and spinning the tire off the rim with a screw driver or 2, or a suitable tool. works great Share this post Link to post Share on other sites
Curmudgeon 28 #2 Posted August 6, 2008 Let me guess, Perry. Does it make the tire wet? B) Share this post Link to post Share on other sites
perry 82 #3 Posted August 6, 2008 :whistle: .. its better than the soap & water that allways dryed up fast that i used to use. BM is alot more slippery. Share this post Link to post Share on other sites
oldandred 15 #4 Posted August 7, 2008 Let me guess, Perry. Does it make the tire wet? Hay Dale dont laugh but i use it on the ball yes spray it on the ball before I drop the hitch makes it go down easy and drys up and want collect dirt and sand. now what else is it used for ?? Share this post Link to post Share on other sites
dmoore 937 #5 Posted April 13, 2011 To blacken your tires! :thumbs: 1 Share this post Link to post Share on other sites
Kelly 1,030 #6 Posted April 14, 2011 How about on a condom?? Sorry it was the first thing that came to mind :thumbs: Share this post Link to post Share on other sites
stevasaurus 22,968 #7 Posted April 15, 2011 Hey Kelly...this post is 30+ months old...still want to use the condom??? :thumbs: Share this post Link to post Share on other sites
JimD 3,345 #8 Posted April 15, 2011 How about on a condom?? Sorry it was the first thing that came to mind I suppose it would lube it all right, but do you blow them up first? :thumbs: Share this post Link to post Share on other sites
HorseFixer 2,013 #10 Posted May 9, 2011 Good Idea coulda used that yesterday on the fron 417A Rims! putting the rubber on. Hey does anyone know of a place that has plastic tire irons or coated so as to not scuff up a new rim? :hide: Share this post Link to post Share on other sites
COMMANDO1 23 #11 Posted May 9, 2011 That stuff that you dip tools into to give rubber handles, you can buy it buy the gallon. Share this post Link to post Share on other sites
HorseFixer 2,013 #12 Posted November 7, 2011 That stuff that you dip tools into to give rubber handles, you can buy it buy the gallon. Well no I was thinking of more like Nylon vinyl or Something On tight Rims. ~Duke Share this post Link to post Share on other sites
ohiofarmer 3,314 #13 Posted June 9, 2016 (edited) I know this is an old topic, but I had an original Raider 10 from 1973 that the previous owner had used Fix-A Flat or some substance that had corroded the tires to the rim. Nothing worked including penetrating oil ,as the weakness of the sidewall and the firm attachment had my buddy joking, "Just burn it off!" Wait a minute. I took a propane torch and started to heat the bead area of the rim in a 12" arc. I did not know exactly how much it would take, but before the rim paint even blistered, some white smoke appeared at the tire, so not more than a minute at the most. Using the same bead breaker that just slid off previously, it popped right off, and a foot stomp broke the rest of the tire free. we were smart enough to have a garden hose ready in case of fire. It was so easy that I could not believe it. Especially on a tire that old Anyway, no damage at all to the rim and tire, except for the horrible Fix-A-Flat. A wheel disc sanding wheel and polycarbonate wheel from Harbor freight got it close enough to hand sand the rest , prime , and paint. A tube now lives inside the old tire with its cracked sidewalls and it still looks OEM. Edited June 9, 2016 by ohiofarmer 1 Share this post Link to post Share on other sites
