gratefulydeadman 25 #1 Posted February 24, 2013 After aome wheeling and deeling over the past couple weeks, I finally got a gt14!! It runs great... no smoke... flawless seat, all 4 original Wheelhorse tires.. 48inch mower deck is almost brand new... I also have the original gas tank for it. I also have a 54inch snowblade that came with my 953. Will that fit on the gt14? Will put pics on in a minute.. Share this post Link to post Share on other sites
Tankman 3,516 #2 Posted February 24, 2013 Score another one for Pennsy! Sounds like a great "find." Let's see the pic's! Share this post Link to post Share on other sites
Jake Kuhn 1,554 #3 Posted February 24, 2013 Sounds cool! Can't wait to see the pics! Share this post Link to post Share on other sites
gratefulydeadman 25 #4 Posted February 24, 2013 Here it is.... 3 Share this post Link to post Share on other sites
546cowboy 301 #5 Posted February 24, 2013 Looks like a nice original tractor. Share this post Link to post Share on other sites
Shynon 7,450 #7 Posted February 24, 2013 Nice looking Gt! What kind of a gas tank did someone put in that one? Tom Share this post Link to post Share on other sites
welderman85 53 #8 Posted February 24, 2013 Great tractor Share this post Link to post Share on other sites
JackC 617 #9 Posted February 24, 2013 Very nice. Looks to be in excellent condition. Those are the real deal. Share this post Link to post Share on other sites
Brrly1 1,146 #10 Posted February 24, 2013 Nice tractor. I totally enjoy mine. 1 Share this post Link to post Share on other sites
boovuc 1,090 #11 Posted February 24, 2013 Was your GT in Loganton, PA perhaps? We had a local GT14 posted here but I need another tractor like I need another head cold. Share this post Link to post Share on other sites
squonk 40,732 #12 Posted February 24, 2013 I need another tractor. There is a hole in my garage where my Goldwing used to sit. Share this post Link to post Share on other sites
gratefulydeadman 25 #13 Posted February 24, 2013 I picked this gt14 up in Hanover, Pa. Does anyone know what modifications I would have to make to put the 54" blade from my 953 onto my gt14? Share this post Link to post Share on other sites
Stigian 1,234 #14 Posted February 24, 2013 Great tractor. I love the look of GT-14's Share this post Link to post Share on other sites
fabricator2009 48 #15 Posted February 24, 2013 Very nice gt. Good luck with it. Share this post Link to post Share on other sites
Brrly1 1,146 #16 Posted February 25, 2013 Whats up? Do you have the quick attach on the rear? More than likely it should fit. I would say without seeing either. The 54" blade is the same width as the GT14 blade. If you have the quick attach on the tractor go ahead and try it. Let us know what happen's. Good Luck Share this post Link to post Share on other sites
gratefulydeadman 25 #17 Posted February 26, 2013 Hey shynon... here is a pic of that gas tank. Not sure what it is from. And for u brrly pics of my plow. I mounted it on the gt14 and it goes up and down as it should. But the only plow bracket I have is just the normal one:( I cant pivot the blade or it hits my wheels. So I have to get the one for the gt14. And does anyone know if the plow feet on the blade are original or not. Thanks Forgot the tank pic. Share this post Link to post Share on other sites
Brrly1 1,146 #18 Posted February 27, 2013 (edited) Good morning, the plow feet are probably original to the blade. You will definitely want to get rid of that gas tank. How does your quick attach bolt to the axle? From front to back or from top to bottom? That will be a start to the problem. More than likely the frame is not long enough. Need to look for a longer frame. Where ya located? Pm me, I have a fuel tank Edited February 27, 2013 by Brrly1 Share this post Link to post Share on other sites
Shynon 7,450 #19 Posted February 27, 2013 Mine is mounted to the front side of the axle. I also have two holes in the blade frame to change the rod position for the quick attach. I have a model 64113 8 frame (best i could make out the numbers) the number 4 is hard to make out. Also from blade to wheel in the straight positon is approx. 13" of clearance and I have had no issues of the blade touching the wheels when in the angled position. Tom Share this post Link to post Share on other sites
gratefulydeadman 25 #20 Posted March 1, 2013 Well problem solved. I picked up a gt14 plow bracket today. Puts the plow forward enough to angle it both ways. Along with that I picked up a set of spare rims and tires for the gt14 (front and rear)!!. They are original tires that say wheelhorse on the sidewalls. Share this post Link to post Share on other sites
Brrly1 1,146 #21 Posted March 2, 2013 (edited) Thats the correct hitch. Do you have the three point attachment? If you do I am sure you see how it all bolts together. Should be stylin' soon. Edited March 2, 2013 by Brrly1 Share this post Link to post Share on other sites
wh1257 226 #22 Posted March 2, 2013 Hey shynon... here is a pic of that gas tank. Not sure what it is from. And for u brrly pics of my plow. I mounted it on the gt14 and it goes up and down as it should. But the only plow bracket I have is just the normal one:( I cant pivot the blade or it hits my wheels. So I have to get the one for the gt14. And does anyone know if the plow feet on the blade are original or not. Thanks Forgot the tank pic. it cant not works you have a short frame snow plow for 753 ,854 ... bud you need a long frame snow plow gt 14 518h 416-8 c 120.... Share this post Link to post Share on other sites
gratefulydeadman 25 #23 Posted March 2, 2013 I actually just started looking for a complete 3point setup for the gt14. I have found 2. What is a good going rate for one? And how many pieces make up the complete hitch assembly? Thanks... ralph Share this post Link to post Share on other sites
varosd 1,185 #24 Posted March 2, 2013 Ralph, You are coming up with some great deals! Maybe you should be called "Gratefully RED man" !!! Share this post Link to post Share on other sites
bitten 134 #25 Posted March 2, 2013 Gratefulydeadman Wow, you have found 2 3-points. I have had my GT14 for a few years and still on the lookout for a 3-point setup. Let me know if one is available. Nice looking tractor you got there. You get it all sorted out and you can keep the (New) Cumberland blues at bay. Brrly Is there a reason you said that he would want to get rid of that gas tank? I mean will it have an effect on the performance of it or is it an originality thing? Share this post Link to post Share on other sites
