T TOWN 0 #1 Posted February 22, 2013 I HAVE A 1976 WHEEL HORSE B112 LAWN TRACTOR. WHILE USING IT ONE DAY I SHIFTED IT AND THE SHIFTER CAME OUT OF THE TRANSMISSION. I CAN PUT IT BACK IN AND THE TRACTOR WILL SHIFT AND OPERATE JUST FINE WITH THE EXCEPTION OF BEING ABLE TO PULL THE SHIFTER OUT OF THE TRANSMISSION. HOW CAN I FIX THIS PROBLEM? Share this post Link to post Share on other sites
953 nut 55,827 #2 Posted February 22, 2013 You will find an allen set screw with a hex nut to lock it at the front of the hole the shifter goes into. On the shifter you will see a small dimple that the setscrew will go into. Just back off the lock nut, insert the shifter, snug up the set screw until the shifter is held in place but moves smoothly then tighten the lock nut. Hope this helps. Share this post Link to post Share on other sites
rmaynard 15,610 #3 Posted February 22, 2013 (edited) Check out this thread: And I read this one without my glasses and didn't see beyond the 1976 B- and naturally my mind thinks B-100. So even though the reference I made may help someone else, it's not relevant to your B-112 Edited February 23, 2013 by rmaynard Share this post Link to post Share on other sites
TT-(Moderator) 1,145 #4 Posted February 22, 2013 A B-112 would be 1980 or 1981...... with a Peerless 3 speed aluminum transaxle. Does it look like this?: Here's a parts list: http://www.odref.com/peerless/601-SERIES/601-601-020.PDF Look at #142 & #146 on the drawing. You'll have to unbolt the shifter assembly & remove it from the transaxle so you can see what broke. Share this post Link to post Share on other sites
IronDuke 4 #5 Posted February 22, 2013 there is a bolt that holds the shifter in, if u look down there u will see it, put it back in or if u do not have one then find one that would fit, screw it in with a nut and u should be good to go Duke Share this post Link to post Share on other sites
