leeave96 488 #1 Posted February 12, 2013 Any reason not to use synthetic oil in the Eaton hydros? I'm thinking about using it with my tranny oil/filter change this spring. Thanks! Bill Share this post Link to post Share on other sites
MalMac 1,332 #2 Posted February 12, 2013 I had a 520H that had synthetic in it and thought it improved the performance somewhat compared to the other 520H that I had just regular oil in. Not saying that will happen for you or anyone else. I am sure there is alot of contributing factors. When I change oil the next time in the one with regular oil I am switching to synthetic. Share this post Link to post Share on other sites
Tankman 3,520 #3 Posted February 12, 2013 I too would switch to synthetic. Less wear 'n tear on the hydro internals. Share this post Link to post Share on other sites
qd-16 14 #4 Posted February 12, 2013 I put syn. oil in my 314h....no problems so far. Share this post Link to post Share on other sites
squonk 42,585 #5 Posted February 12, 2013 I run Mobil 1 in my c160 Sunstrand. Share this post Link to post Share on other sites
dbartlett1958 96 #6 Posted February 13, 2013 I use synthetic oil in anything that has an oil pump, or any engine that will get run/started in the extreme cold. When you see how conventional oil pours(or rather does not) at -20F, you will never use anything other than synthetics. Although one could use thinner conventional oils for colder temps, I find the temperature range of those too confining. Many years ago, Quaker State had a batch of oil that had a bad additive package. When the temps dropped to freezing, this particular oil would literally congeal and not flow through the oil pumps. Many an engine was ruined at cold start. Try selling Quaker State in Aroostook county today. Farmers there have long memories when it comes to spending money. Share this post Link to post Share on other sites
shallowwatersailor 3,214 #7 Posted February 13, 2013 I have used Mobil 1 10W-30 in my 518xi's Eaton 11 for three years without a problem. Because I had a car that used the same oil viscosity at the time, I bought a case of it at a warehouse club. I would probably look for an AMSOIL product now. Share this post Link to post Share on other sites
smoreau 658 #8 Posted February 14, 2013 I have 3 tractors that I changed to Mobil 1 10w30, and it has improved performance on all 3 with quicker lift operation in winter too less noise under load! The full synthetic oil will take the heat of a hydro without breaking down and will last 3-4 times longer then conventional oil. Any one thinking of changing over to it, Why are you waiting? Share this post Link to post Share on other sites
Kevbo 80 #9 Posted February 14, 2013 Hey guys would I be able to put Mobil 1 10W-30 synthetic in my 1075? Right now it has automatic transmission fluid in it... Share this post Link to post Share on other sites
smoreau 658 #10 Posted February 14, 2013 You need to get all of the auto trans fluid out of the trans. I would change it to a synthetic blend oil first, then switch to the Mobil 1 Share this post Link to post Share on other sites
Kevbo 80 #11 Posted February 14, 2013 Is there any way to flush it or just put 10W-30 blend and run it around awhile? Is motor oil better than ATF in this situation? Share this post Link to post Share on other sites
Trouty56 567 #12 Posted February 14, 2013 I'd just let the ATF in there....motor oil suspends contaminates and holds them so they can be filtered. This is OK but the filter is at the end of the flow in this case. ATF will let the contaminates settle so they can be drained. IMHO 1 Share this post Link to post Share on other sites
Kevbo 80 #13 Posted February 14, 2013 Thanks trouty! Share this post Link to post Share on other sites
Kelly 1,030 #14 Posted February 14, 2013 Use synthetic ATF, and I like Mobil 1 in my hydro's Share this post Link to post Share on other sites
Wheel-N-It 2,971 #15 Posted February 14, 2013 Bill, the all knowing and powerful DUKE of the Snow Chunker fame advised me to use Mobile One 10w-30 in my 417-A. I took his advise and so far no problems. 1 Share this post Link to post Share on other sites
73-18 automatic 8 #16 Posted February 14, 2013 I have been using Amsoil 30w synthetic in my D for 3+years and I like it very much 1 Share this post Link to post Share on other sites
Kevbo 80 #17 Posted February 15, 2013 So this weekend I will put new oil in my 1075 hydro but I'm still unsure if I should go synthetic motor oil or ATF. Kelly you mentioned Synthetic ATF - what brand? Share this post Link to post Share on other sites
Kelly 1,030 #18 Posted February 15, 2013 I run Mobil 1 in my race car, engine oil, trans fluid, and gear oil, I also run it in my keeper tractors. Share this post Link to post Share on other sites
Forest Road 594 #19 Posted February 15, 2013 I have Amsoil in my 314 h and the 522xi will be getting a full flush this summer. Share this post Link to post Share on other sites
Machria 78 #20 Posted February 15, 2013 Synthetic 30w motor oil would be ok in a GT14 hydro? I just got it, and was about to go get somekind of hydrolic fluid. Share this post Link to post Share on other sites
smoreau 658 #21 Posted February 15, 2013 Go with 10w30 Share this post Link to post Share on other sites
Trouty56 567 #22 Posted February 15, 2013 (edited) GT14 probably has ATF in it but maybe not. Check the dip stick to see if it is red in color. If it is red then would stay with ATF until you research converting it a little. You can drain the fluid, whether it be AFT or motor oil, and change the filter. Here is a thread on a couple filter choices....I use a NAPA 1410....some guys swear by Toro. I point this thread out because there is a cool tip on inserting a magnet into the tranny plug. If you are insistent on using synthetic go ahead and use it but I would stick to the fluid type that is presently in the system until you have a better knowledge of your tractor. When you fill the trans fill it slowly till you read full....might be 4 qts give or take. Run the tractor a little to move the oil. then fill it more until the level stays consistent. The full amount in the manual will not fit at first. Edited February 15, 2013 by Trouty56 Share this post Link to post Share on other sites
Machria 78 #23 Posted February 15, 2013 Thanks Trouty. (Your not Trouty from The hull Truth a few years ago, are you?) I'm pretty sure it has the pink ATF stuff in it now. But I'm draining it all out, new filter and will refill. 1 Share this post Link to post Share on other sites
Kevbo 80 #24 Posted February 15, 2013 I've decided to put Mobil 1 Synthetic ATF in my 1075. Thanks for the advice everyone! 1 Share this post Link to post Share on other sites
Trouty56 567 #25 Posted February 15, 2013 Thanks Trouty. (Your not Trouty from The hull Truth a few years ago, are you?) Maybe....lol Share this post Link to post Share on other sites
