tommyg
Custom Weights and Chains for a D
tommyg
After some inspiration from a few members for wheel weights and chains, I decided to put my thinking cap on and design some tire chain tensioners and wheel weights for my D180.
I found some spring type tensioners from a few vendors on ebay, but decided that none of them had enough springs to do an adequate job. After some hunting, I ended up finding some springs at Home Depot, but they ended up being too long. So I cut each of them in half, then heated the end and formed a new loop in which to pass a 1/8" vinyl cable through. Purchased 4 springs for each wheel, which gave me 8 springs per wheel when I was through. Ended up with just the right amount of tension to tighten the springs equally all the way around.
More to follow... Seems I can never add more than 4 pics at a time.
tommyg
Once that part of the project was complete, I moved on to adding weights to the wheels. Working at the Y in town, I was able to nab a set of 125 York dumbbells that were put away in storage never to be used again. Went to the local surplus store and picked up some square a 1 1/4" square stock and set out to make a fixture that would support the weights. I used the 1" bar from the barbbell set as the center stock piece and welded it all together.
Drilled holes in the fixture and got it mounted to the wheel.
Then all painted up.
tommyg
Next, I went about painting up the weights and got everything mounted.
The end of the barbbell shaft was drilled and tapped for a collar that held the weights on. So I took advantage of this and used it to secure the weights on.
That's all! Just thought I'd share it. Turned out pretty good and added 125 pounds to the rear end of my D.
  • Like 4
"D"- Man
Looks really good, just goes to show where there's a will there's a weight!!! Mark.
KC9KAS
Very nice job with the springs and the weights.
Kelly
Looks very good.
rexman72
very well done
Tankman
Adding this to my famous quotes. Thank you Mark. You will be quoted often. :ychain:
Nice neat job on the D chains 'n weights too!
varosd
using the barbell weights is great and if are plowing and get a notion to do a little......
tommyg
Pretty funny varosd! There's a Planet Fitness right at the end of my street.
1maidenfan
Great job on the weight bracket, looks awesome!!!
I also added weights on my 'D' the same way, works great and much cheaper than buying factory weights.
wheeledhorseman
Neat solutions on both counts - thanks for posting them. :thumbs:
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
    • Southern_Secret
      By Southern_Secret
      Hello fellow Horse Heads long time no post for me, life gets crazy & a lot of things change sometimes but anyhoo. So back a few years ago when I first got my 1994 314-H I had it at my shop going threw it. One of my customers walk past as im working and said, you know I think Iv got a Wheel Horse & im thinking "no you dont buddy". I give him my # to send pics thinking it was a big waste of time & after getting the pics I realized he did have a Wheel Horse! I hand shake bought it right there, asked him to bring it to my store & he said no problem. Well after almost 2 years it is finally in my orbit. I know very little about it other than his father-inlaw got it new and used it around his house moving snow and stuff. His father inlaw moved down south here when his daughter got married and gave the tractor to my customer because he had a farm & his the inlaw had no use for it anymore. Same with every barn find, "it was running when parked" 8 years ago, said one of the axel seal is leaking. Im happy and hope I can get it back in running order soon cause it is going to be handy around the truck farm!!
      I will post Pics as soon as I reinstate my membership
    • Swemill
      By Swemill
      Hi everyone!
      Long time since i was here and my old pics is gone from the forum.
      I just uploaded a movie with pics on youtube, and thought i could share it for you guys.
      I would love to get some comments on my Youtube channel, from you true Wheel Horse fans!
      Thanks and Best Regards
    • Nathan W
      By Nathan W
      Does this look factory for 1976
